I'm probably just blind, but I did look in RH's help and I still couldn't find where it says how to set the default TOC if you have multiple TOCs. Can anyone provide some needed elucidation?
Jared
RH7, Vista
PS... Is it also possible to define signatures for our profies to put automatically into posts? If so I don't see where? (sigh) It's one of those days when I feel like I need new eye glasses.
Hi Jared
When you create a RoboHelp HTML project from scratch it will have a single TOC and it will be labeled as the default. Of course you may now create more than a single TOC. If you have more than a single TOC, you expand the Table of Contents pseudo-folder in the Project Manager. Right-click the desired TOC and choose Set as Default.
Note that you may also configure a specific TOC to be used in the Single Source Layout properties.
There is no signature capability in the new forums. You have to add the code manually to each post if that's what you want.
Cheers... Rick
Hi Rick,
Thanks for the response. At least I know I'm not totally blind. I was indeed looking in the right place to set this before posting. But strangely, I don't have a Set as Default menu item when right-clickinng and viewing the popup menu.
Suggestions?
Hi Jared
So sorry. My bad. I failed to notice in your first post that you clearly stated you were using RoboHelp 7. I was just looking at my RoboHelp 7 and you are correct. That option isn't there in RoboHelp 7. What I shot back earlier was for RoboHelp 8. So it would appear that's one of the changes that were added to version 8.
The good news is that RoboHelp 7 *DOES* support the other method I mentioned. Choosing the TOC for the layout.
Cheers... Rick
I appreciate the response. I at least know how to assign a new TOC as a single source layout in RH7. But is there a way to change the default one in RH7? A registry entry or something?
Hi there
Sorry, but not in version 7. It's a feature that was added to 8.
Cheers... Rick
Helpful and Handy Links |
Thanks. Seeing as ahow that is not possible, what about deleting the default TOC inside RH7, so that my secondary TOC is the only one available? How would I do that?
Hi there
I think if I were to consider that, here is the approach I would take.
Before you do any of this, make a backup copy of all your project files.
Right-click any topic and choose Topic Properties or Properties.
Click the File tab.
Click Open Folder. (This should open Windows Explorer in the project folder)
Dismiss the dialog and close RoboHelp.
Locate the default TOC file. This file should be named identically to your project and have a .HHC file extension. Delete this file.
Copy the desired TOC file. (it should also have a .HHC file extension)
Rename the copy to match the default TOC file you deleted earlier.
Restart RoboHelp and your TOC should now contain what you want.
From inside RoboHelp, delete the second TOC.
Hopefully this helps... Rick
