Thanks Miker. Worked like a charm. I'm sure it helps to know
a little XML, or maybe more of how XML works with WebCharts3D. If I
wanted to know what other things I could control via the <SERIES
0> and <SERIES 1> tags, do you know of a good reference
source?
I do have one last question. Is there anyway to incorporate
the changes I just made "manually" in the .XML file, using
WebCharts3D and the .WCP file? Reason is, I usually open and work
with the .WCP file, then save it as an XML file. If I re-open the
WCP files, add more changes, and save it to XML, I'll lose the
changes I just manually added.
Of course, I know now I can manually go in and add these
SERIES 0 and 1 tags to get what I need. Would just be nice not to
have to do that everytime I make a change, using the .WCP file. I
suppose if you're an XML expert, and experienced with WebCharts3D,
you probably work directly with the XML file. I'm not yet that
skilled with XML.
Thanks again for your help. It's great when things work,
ain't it?
Gary
