I'm finishing up on a project in RH6 after a 6 month layoff, so I'm a bit rusty! However, I just discovered that the images that I added to text boxes no longer show up when topics are generated or printed-out (they do show in the project manager view). Any clues out there? Thanks.
I want to ask why you have images in text boxes but maybe I won't .
Perhaps instead you can elaborate on what you are seeing. Is there a placeholder for the image but no image or is there nothing at all inside the text box. Also is this only happening in the generated output (I'm assuming from your words this is webhelp?) in which case I'm wondering if this is a browser issue.
Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
I placed the images in the top left corners of the text boxes to distinguish between different "tip" boxes used throughout my manual.
There isn't a placeholder for the image (jpg.). I wish I could recall right now how I did this, but somehow I was able to create the text boxes with the images "imbedded" - I can't click on the images alone. Yes, this is webhelp. The problem occurs when I either: view the topic in project manager (CTLR + W), generate the primary layout, or access the published version from the web. The text is still shown in the box, but the images aren't there. The only place the images still appear is directly in project manager. Sorry, I can't provide more info. I probably need to try recreating the same text boxes in order to figure out what's going on. Thanks
In case anyone is interested in adding a little "spice" to their text boxes, I did figure-out (remember) how to imbed images into text boxes.
In this way, the image is imbedded as a pattern rather than an image.
Hi there
Thanks for sharing. Looks interesting.
However, I might suggest the following amendment to your instructions:
- 1) Create an image and save as jpg. in your project folder (I'm thinking the image type makes no difference)
- 2) Insert text box into desired topic(s)
- 3) Right-click text box and select "text box properties"
- 4) Under "Shading" tab, select color and then insert desired image under the "Pattern" section
- 5) Under the "Repeat" section, select "No-Repeat" and keep the "Scroll box" checked-on
Cheers... Rick
You're probably right - thanks!
