I am using the script from: http://www.coldfusionjedi.com/index.cfm/2009/2/19/Using-jQuery-to-add-form-fields to dynamically add fields to a form. I am having trouble actually inserting the fields into a DB. It seems that the field name is the same each time so they just get combined into one variable. For instance, if field 1 is "John" and they add another person and his name is "Frank" field1 becomes, "John, Frank".
I have a few more fields then that, so I am unsure how to proceed. Anyone have any ideas or code samples that have worked for them? Essentially I am trying to loop through the form and insert each additional field seperately.
Any ideas?
Thanks a ton
Nested loops. Outer loop is your formfields. Inner loop is each field (treat them as lists).
Thanks for the help! I am still stuck as to exactly how this will be done. My form is as follows:
Type:
Price:
Unite:
Name:
and users can add another product etc so there will be more fields for each additional product (which all seem to get truncated as a comma seperated list in the form value)
Here is what I have so far, after the form is submitted:
<cfloop item="key" collection="#form#">
<cfquery name="insertnote">
INSERT INTO Deals (type, price, unit, name) VALUES ('#form.type#', #form.price#, '#form.unit#', '#form.name#' )
</cfquery>
</cfloop>
I honestly don't use loops like this very often so I apologize for having a lack of understanding. I know you mentioned making them nested loops but I dont' know how to do it and have it successfully insert the appropriate data. Everytime I try it doesnt come out right.
Hopefully, each time the user adds a product, something is appended to the end of every form field. It becomes very easy. In fact you don't even need nested loops.
<cfloop from = "1" to = listlen(form.name) index = "i">
INSERT INTO Deals
VALUES
('#listgetat(form.type, i)#', #listgetat(form.price, i)#, '#listgetat(form.unit, i)#', '#listgetat(form.name, i)#' )
</cfquery>
Also, cfqueryparam for a number of reasons.
