Using Captivate 3, recording using Full Motion. Several full motion slides were fine, but one gives me a blank white page when I preview using next 5 slides, From this slide, or project. I can even hear the audio, but I see nothing. When I preview just the slide, I can see it working fine. I've deleted it and re-recorded it, left out the audio, put the audio back in. Nothing seems to work.
I've renamed the captivate_v30.dat file and re-opened Captivate to no avail. This never happened in 2.0, is there an issue in 3.0?
Thanks in advance.
Barb
Hi there
Flash Player 10.
Downgrade your player to Version 9 and it should allow things to work okay with Captivate 3.
Cheers... Rick
Thank you. That did the trick. I don't suppose you know if Captive 4 is compatible with Flash 10...
Hi there
To the best of my knowledge it is. However, I'll also add that I've seen reports here of other issues where preview goes wonky in Captivate 4. I believe it's a resource issue and not a Flash Player issue. But I could be wrong about that.
Cheers... Rick
