After Effects Cs4 And Windows 7
Feb 10, 2009 Feb 10, 2009
Is cs4 incompatible with windows 7?
i installed it all successfully and when i try to run the program, the liscense agreement pops up and i click agree, then i just get the error sound and the program never starts up
I do run it as a administrator
and other adobe programs seem to work just fine on my pc
By the way, i have the trail version of cs4
24.3K
Sounds like you've answered your own question...? :-)
I just downloaded it yesterday
i still have another 30 days left
the program just won't start for some reason
and i'm asking if its windows 7
because photoshop runs just fine with windows 7
Guest
windows 7 ??? what or who is windows 7 ?
are you beta testing new windows software? it does not pop up in the AE CS4 min. rec. sys. specs...
Brandon, please understand that nobody will be able to help you on that. W7 may look and feel like Vista, but it isn't. Hence nobody can give you any guarantees that a software not officially developed with it in mind will run on it. If you don't know which buttons to push, you're on your own, mostly. As a minor, try to launch the Adobe Licensing Service manually and unblock it in your firewall. This may help. Also check, whether your Users\All Users\AppData and similar directories are fully accessible.
Mylenium
Feb 11, 2009 Feb 11, 2009
Yes,
i was just making sure if anyone else had the same issues, because other adobe programs work just fine with windows 7, except for after effects
But i appreciate the help Mylenium
May 18, 2009 May 18, 2009
I'm having problems with After Effects on Windows 7 (64-bit), too. I'm running the release candidate and AE fails to start up. It displays the splash screen but then never finishes starting. Photoshop, Dreamweaver, Fireworks, Bridge, Flash and Flex are all working OK so it appears that it's just an After Effects problem. Too bad, because I'm very pleased with my experience with Win 7 so far. It's still early days but, in general, it appears to run better than my Win XP x64 installation. I guess I'll have to boot back into that old OS for running AE.
David Salahi
Have you checked your graphics card settings and driver? Most such failures are related to the GPU sniffer producing nonsense results due to the drivers still being Betalized. Also try to manually turn off some of the fancies for Aero and such. I'm not sure, since I'm staying away from W7 for the time being (just got a new core7i with Vista 64 and not feeling adventurous), but you may also need to work your way through that changed media handling stuff and Quicktime. I tend to think there is certainly some "legacy" switch for DirectDraw CoDecs in the control panel somewhere. Just a few random thoughts on the matter, of course, but may be a starting point.
Mylenium
May 20, 2009 May 20, 2009
Mylenium,
Your suspicion was right on. In my case, the problem turned out to be the ATI Gamer OSD (on-screen display) software.  I uninstalled it and now After Effects is working fine on Windows 7 RC.
Thanks for the tip!!
David Salahi
May 21, 2009 May 21, 2009
Glad it worked out!
Mylenium
Oct 17, 2009 Oct 17, 2009
Hello! I need some help! i have installed win7 and after effects cs4 and activated, but the window telling me that it;s going to install some codecs never appears. same with Soundbooth CS4. Can you tell me what the problem is?
The only thing I can think of is a general solution that has worked for me with a number of programs that stopped functioning under Windows 7: run the programs in Administrator mode. Right-click on the program or shortcut and do Run as administrtor.
Hope this helps,
David Salahi
http://artistic-webdesign.com/
Jul 09, 2010 Jul 09, 2010
I just found out the solution to this problem.
The problem is the video codecs, install klite player 6xx x64 or x32 depending on operating system you work on.
Download the klite player 6xx update, install 3ivx_MPEG-4_502_trial_win, and your problems are history.
gr peter
