Hello,
Is it possible to insert images as clickable thumbnails? So, when a user clicks 'click here to see larger image' the image displays in a larger size?
Thanks.
Hi there
Yes this is possible. What you do is to create two versions of each image. One is the thumbnail and the other is the full size image. You then create links from the thumbnails to the larger images.
There are a variety of ways to approach this. Without knowing more it's hard to direct.
For example:
Cheers... Rick
Thanks for the speedy reply.
A bit more info, I'll be outputting WebHelp from RH 8.
I don't want a popup or a new window. So, am I left with using a DHTML link.
I really just want the larger image to appear next to the thumbnail. Has the hotspot functionality changed for the good. I was always disappointed when white space was reserved for the popup image, leaving a gaping hole in the non-expanded layout.
Again, thanks very much.
Hi again
If you are referring to the RoboHelp Popup method, hopefully you realize you may specify the dimensions of a Popup. You may see a small white border, but nothing hugely large or unsightly. (Unless you just WANT it that way. )
Cheers... Rick
Actually, not the popup...
I don't have RH in front of me, so please excuse my lack of accurate terms. I'm talking about the DHTML feature that allows me to specify that an image should expand/contract upon a user click. In the past, when a graphic/text was marked dynamic so it rolls up/rolls back upon click, the white space required for the expand appeared even in contracted view. This could be old news (v5).
If this description doesn't suffice, I'll get the actual terminology and get post a more helpful query.
Again, thanks.
