I am compiling 20 separate captivate courses into one course using Adobe Captivate 4.0
When I try and import slides into the complete course it does not import the correct type of captions. The captions revert to the standard adobe blue caption.
I compiled this way fine with Captivate 3.
Is there a way to compile my individual Captivate course into one and keeping the same captions.
Just wondering if you dont have to make any changes to your master course (20 courses compiled), then you can make use of Aggregator feature of Captivate. It should not also create the text caption problem as it aggregates individual published movies.
Mukul
You can try to copy paste the slides from projects into the compiled one.
If this doesn't work then it might be a project corruption issue.
Manoj
Mukul
