In RoboHelp 8, HTML Help Output with .chm deliverable, is it possible to change the color of the frame borders?
Hi there
I'd say it depends on what you are referring to. Some influence is there but not much. Which "Frame" is it? Can you post a screen capture pointing out what you hope to change?
Cheers... Rick
Thanks for your response! I'm referring to the frames and borders in the help browser window. One of our programmers wants the gray on the help browser to match the color of our application. Is this possible? Attached is a copy of the help browser. Can the gray be changed to another color? Thank you.
Hi, Ron,
I don't believe that you can do more than what is described in this page:
http://www.help-info.de/en/Help_Info_HTMLHelp/hh_xp-style.htm
Long story short, Microsoft did not anticipate a requirement to make cosmetic changes to the Help viewer in its design of HTML Help.
Pete
Thank you for the explanation and the workaround. It helps to have an answer to take back to my programmers.
