I've just installed Adobe Pro 9 yesterday. I'm using Live Cycle to design some forms.
I wanted to use a drop down list from our db. Even though this worked, it does not let me expand the list. So I tried to generate a list of my own as a test.
Select dd list -> Object -> Binding -> Default Binding = None
When I try to select "Specify Item Values" I find that it's greyed out. Anyone know why is this?
thanks
Total Likes
Did you set up a dataconnection to the DB so that you coudl pick the column that shoudl be bound to your list?
Paul
Total Likes
Paul,
Yes I did set up a connection. I can see the table that I selected in my data view. The data does display in my dd list but not in sequential order.
Aside from my data, what's worrying me is I don't seem to be able to generate a list manually ie "Specify Item Values" is greyed out
thanks,
Paul
Total Likes
My guess is that you do not have Dynamic Properties turned on. Go to Options/Bindings and turn them on this way:
thanks..
Total Likes
