I've posted this on another thread, but it seems to have got lost amongst the other posts.
First I want to make it clear that I have done all the updates possible.available to both the Sony reader,,Adobe DE and eBook Library.
I have authorised the Reader and Adobe DE and I have an Adobe ID.
Both e-Book Library and Adobe DE 'recognize' the Sony reader as the PRS 505 icon appears on both bookshelves.
The Reader was purchased, legitamately in the UK [John Lewis]
I can purchase books OK - downloaded one to Adobe DE from Waterstone's UK.
When I attempt to drag the title into the 505 ir refuses to let me ["No permission to copy document here"]
If I attempt the same within e-Book Library [I can get the book across to here by importing from My Documents] I'm again refused permission [ To tranfer this e-Book yoy must first authorize the Reader for Adobe DRM protected content. Would you Llike to launch Adobe Digital Editions and authorize the reader now?]
If I click YES Adobe DE opens, but I'm given no prompt to authorize. when I click on Authorize Computer on the drop down menu it tells me "this computer is authorized to..." followed by my e-mail address which is also my Adobe ID.
It's a hideous circle I can't escape from and makes the Reader virtually useless.
Contacted Adobe Support but after a couple of e-mails where , essentially they said " are you sure you've done everythingh right" my case has now been referred to the Technical Dept - and things have gone very, very quiet.
Anyone out there have a clue what I do next.
Note: Beyond the basic operations I an no computer whizz!
If Ctrl-Shift-E isn't working that most likely means that your Sony Reader is not authorized with an AdobeID.
If Digital Editions isn't asking you to authorize your Sony Reader with your AdobeID when ADE starts or when you plug in the Reader this means you told it not to ask you any more (clicked on the Don't ask again for this device checkbox).
Unfortunately there is no easy way for you to undo this. The list of devices is stored in the manifest.xml file which is stored in your My Digital Editio
...Copy link to clipboard
Two possible answers.
First if you can see your Sony Reader in the list of Bookshelves in Digital Editions, deauthorize your device in ADE (Ctrl+Shift+E), unplug it, and replug it while ADE is running. ADE should bring up a dialog to allow you to authorize the device.
Second if you can't see your SonyReader in the list of Bookshelves, then reinstall your Sony softare - you are missing the piece which allows ADE to communicate to Sony Readers. Once you have done this when you plugin in your Sony Reader with ADE running it should bring up the device authorization dialog.
Jim,
Thanks for the reply.
Sadly, neither of these help.
1) The icon does appear on the shelf, but Ctrl+shift+E does nothing. If I manually unplug the Reader, the icon disappears, then re-appears when I re-insert USB cable. But no prompt to authorise.(nb I'm presuming we are talking about the 'up arrow' when we talk about 'shift')
2) I have tried re-installing software, but it makes no difference.
Any other ideas?
Larry Barker
Unfortunately there is no easy way for you to undo this. The list of devices is stored in the manifest.xml file which is stored in your My Digital Editions directory (under My Documents).
To modify the manifest.xml:
1.) Quit Digital Editions
2.) Make a backup copy of the manifest.xml (call it something like manifest.good)
3.) Open manifest.xml in notepad
4.) It will appears as one big long line of xml, and you are looking for a tag called <de:deviceID> start at the begginning of this and select until you the end of the tag that looks called </de:deviceID>
5.) If you have attached more than one Sony Reader there may be multiple of these. Delete all of them to make sure.
6.) Save the file (manifest.xml) and quit out of notepad
7.) Ensure you have the Sony Reader plugged in
8.) Launch Digital Editions
9.) The Device Setup Assitant should come up.
a.) Do NOT click on the "Don't ask again for this device" checkbox.
b.) Do click on the "Authorize Device" button.
IT WORKED!
Thanks a million.
It does seem insane that such a tiny mistakle (I don't remember making,BTW) so early on can so completely knacker the thing.
Anyway, thanks again.
Larry Barker
Lazard,
Well done. I have the identical problem and have had for 5 motnhs i.e. my ebook is totally useless.
Adobe have not been able to resolve it.
Judging by the reaction from the OP, you have solved it.
Unfortunately I dont have a clue what you said.
Is there any chance you could post it in idiots terminology or is it just too complicated?
As I said earlier I am no computer whizz but this wasn't to hard.
Jim Lesters post with the Gold Star is the one to folllow.
First you need to find this manifest file - go to My Documents, then to My Digital Editions and you'll see a file called manifest .xml - right click on this and Open with ..'Notepad'.
First, under File choose 'save as..' and give file another name eg 'manifest back up'. This is just a copy in case you mess things up!
Now, you'll get two lines of gobbledegook that go across the page -keep scrolling across till you find the bit of code that Jim talks about. (Point 4 on his list) Delete this, then save the file.
Close file, plug in Reader then open Adobe DE . It SHOULD ask you if you want to authorise device - click on 'Authorize Device'.
DO NOT CLICK ' Don't ask again for this device'! - this is where it all went wrong in the first place.
You should be OK now
Jim's post is pretty simple to follow, so if you can use his step by step guide - I've just tried to fill in a few of the gaps.
Hope this helps.
if you feel it's beyond you, someone with a bit more computer savvy should easily be able to do it.
Ask a mate!
This worked for me!. Thanks a bunch. I have spent the better part of 2 days trying to download items to
my nook.
I am dipping way back into time, here, and responding to Jim Lester's paragraph:
"Second if you can't see your SonyReader in the list of Bookshelves, then reinstall your Sony softare - you are missing the piece which allows ADE to communicate to Sony Readers. Once you have done this when you plugin in your Sony Reader with ADE running it should bring up the device authorization dialog."
This is embarrassing, but how do I reinstall my Sony software? (ADE is not automatically detecting my Sony reader as it is supposed to.)
You should delete the software first..and reinstal with the CD that came with the reader. Good luck! I got so fed up ..I sold the reader ..and I'm moving to iPad....
Thank you!
I HAVE EXACTLY the same issue, and I followed the suggestions religiously.....BUT there was NO </de:deviceID> anywhere in the string!!!! So was not able to authorise my new laptop....ANY OTHER IDEAS????
I have almost the same problem. There was no <de:deviceID> for me to delete. I can however, deauthorize my e-reader and re-authorize it. But I still cannot transfer my downloaded book from ADE to my e-reader. I still get the message "No permission to copy document here". HELP please! 🙂
I, too, had the same problem with my Nook (Barnes & Noble e-reader). I just want to say THANKS for the advice. It all worked fine for me and I'm feeling an inch more computer saavy this morning. No problem re-authorizing once that ID line was deleted.
Is there a difference in the way the information is stored on a Mac? I'm using OSX, and there is no mention of 'deviceID' in the manifest.
My guess is yes. I'm not at all familiar with Macs, but I wonder if you have
an istore nearby if you could check in with one of their people?
Good luck...it's a great system once it is set up!
LO
ADE relies on device drivers to talk to the Sony Readers. There are no such device drivers for ADE on the Mac. You will need to use the Sony Ebook Library software to transfer your content on the Mac.
I'm sorry to have caused confusion: I was piggy-backing on the discussion of why the key-strokes didn't work in ADE. I have an Onyx Boox, with which I am having similar problems to the original poster. The Boox comes equipped with ADE, and is supposed to talk directly to ADE; it may be that the missing information is on the reader rather than on the Mac.
Have you sorted your problem yet? I also have a boox
Nope, sold it.....support was abysmal..good luck.
I was able to load the book from ADE to the Boox after installing the most recent version of the firmware. Probably resetting the Boox would have the same effect. I had also uninstalled and reinstalled ADE, but I don't know that this was necessary.
tried that, still does't work!
Did the firmware actually install? I had a little trouble getting it to do so. If it worked, the interface is completely different. If it isn't that, I don't knwo what to suggest. You could ask your question here.
how is the interface different? then I will know if it installed. Thankyou
for your patience and help
DrPenNZ
Problem solved! Don't really need the ADE at all.
Glenn
