Show 2 replies
1. Re: PE4 aborts while compiling a video
Paul_LS May 20, 2009 2:10 PM (in response to Wumpus32)Your problem is the DivX format... it is intended for delivery rather than editing. What you can try is, rather than burning, try to export your whole timeline as a DV-AVI... File>Export>Movie. Then bring this into a new project add your DVD markers and menu and then burn.
If this is unsuccessful you will need to convert your files to DV-AVI... MPEG Streamclip can do this see this FAQ:
2. Re: PE4 aborts while compiling a video
Bill Hunt May 20, 2009 4:17 PM (in response to Wumpus32)I am surprised that you got as far as you did with the DivX CODEC. Usually, these fail to Import with full Audio and Video. Something usually fails.
The best format to convert to is DV-AVI Type II. Most other CODEC's will cause problems at some level.
Good luck,
Hunt
