facing error Remote EJBObject lookup failed for ejb/Invocation provider
Avatar
Former Community Member
Hi SupportTeam,
We are facing problem while invoking an EJB service running in Websphere 6.1 through our client (with the program "ConvertWordDocument.java").
we are using the following jar files in our client.
1) adobe-generatepdf-client.jar
2) adobe-livecycle-client.jar
3) adobe-usermanager-client.jar
4) adobe-utilities.jar
5) naming.jar
6) namingclient.jar
7) j2ee.jar
8) ws_runtime.jar
9) ibmorb.jar
10) ibmorbapi.jar
Could you please help us and let us know what are the jar files needed to invoke that EJB service through our client which is using Sun JDK 1.5.
Below is the code we are using.
import java.io.File;
import java.io.FileInputStream;
import java.util.Properties;
import javax.naming.Context;
import com.adobe.idp.Document;
import com.adobe.idp.dsc.InvocationContext;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactoryProperties;
import com.adobe.livecycle.generatepdf.client.CreatePDFResult;
import com.adobe.livecycle.generatepdf.client.GeneratePdfServiceClient;
import com.ibm.ws.install.configmanager.utils.HashtableUtils;
public class ConvertWordDocument {
public static void main(String[] args)
  try{
  //Set connection properties required to invoke LiveCycle ES
  Properties connectionProps = new Properties();
  connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT_EJB_ENDPOINT, "iiop://esealvm343.al.sw.ericsson.se:2089");
  connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
  connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_TYPE, "WebSphere");
  connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_USERNAME, "administrator");
  connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENTIAL_PASSWORD, "password");
  //Create a ServiceClientFactory instance
  ServiceClientFactory factory = ServiceClientFactory.createInstance(connectionProps);
  //Create a GeneratePdfServiceClient object
  GeneratePdfServiceClient pdfGenClient = new GeneratePdfServiceClient(factory);
  //Get a Microsoft Word file document to convert to a PDF document
  String inputFileName = "C:\\sun.doc";
  FileInputStream fileInputStream = new FileInputStream(inputFileName);
  Document inDoc = new Document(fileInputStream);
  //Set createPDF parameter values
  String adobePDFSettings = "Smallest_File_Size";
  String securitySettings = "No Security";
  String fileTypeSettings = "Filetype Settings";
  //Convert the Word document to a PDF document
  CreatePDFResult result = pdfGenClient.createPDF2(inDoc,inputFileName,fileTypeSettings,adobePDFSettings,securitySettings,null,null);
  //Get the newly created document
  Document createdDocument = result.getCreatedDocument();
  //Save the converted PDF document as a PDF file
  createdDocument.copyToFile(new File("C:\\testdoc\\sunejb.pdf"));
catch (Exception e) {
  e.printStackTrace();
  System.out.println("Error OCCURRED: " + e.getMessage());
The Complete error we are facing is given below:
ALC-DSC-031-000:
com.adobe.idp.dsc.net.DSCNamingException
: Remote EJBObject lookup failed for ejb/Invocation provider
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.initialise(
EjbMessageDispatcher.java:97
at com.adobe.idp.dsc.provider.impl.ejb.EjbMessageDispatcher.doSend(
EjbMessageDispatcher.java:130
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(
AbstractMessageDispatcher.java:57
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(
ServiceClient.java:208
at com.adobe.livecycle.generatepdf.client.GeneratePdfServiceClient.createPDF2(
GeneratePdfServiceClient.java:519
at ConvertWordDocument.main(
ConvertWordDocument.java:86
Caused by:
javax.naming.NamingException: Failed to initialize the ORB [Root exception is java.lang.ClassCastException
: com.sun.corba.se.impl.orb.ORBImpl]
at com.ibm.ws.naming.util.Helpers.getOrb(
Helpers.java:294
at com.ibm.ws.naming.util.WsnInitCtxFactory.getInitialContextInternal(
WsnInitCtxFactory.java:373
at com.ibm.ws.naming.util.WsnInitCtx.getContext(
WsnInitCtx.java:112
at com.ibm.ws.naming.util.WsnInitCtx.getContextIfNull(
WsnInitCtx.java:422
at com.ibm.ws.naming.util.WsnInitCtx.lookup(
WsnInitCtx.java:143
at javax.naming.InitialContext.lookup(Unknown Source)
EjbMessageDispatcher.java:88
... 5 more
Caused by:
at com.ibm.ws.orb.GlobalORBFactory.init(
GlobalORBFactory.java:82
at com.ibm.ejs.oa.EJSORBImpl.initializeORB(
EJSORBImpl.java:174
at com.ibm.ejs.oa.EJSClientORBImpl.<init>(
EJSClientORBImpl.java:97
EJSClientORBImpl.java:73
at com.ibm.ejs.oa.EJSORB.init(
EJSORB.java:386
Helpers.java:285
... 11 more
Error OCCURRED: Remote EJBObject lookup failed for ejb/Invocation provider
Avatar
Hi Jasmin,
I have gone through the document but didn't find any solution.
Thanks and Regards,
Sunitha.
Jasmin Charbonneau <forums@adobe.com>
19/05/2009 18:33
Please respond to
clearspace-1443482828-1NEw-2-8hjg@mail.forums.adobe.com
To
Sunita Nookala7/India/IBM@IBMIN
cc
Subject
Re: facing error Remote EJBObject lookup
Have you read the following documentation:
http://livedocs.adobe.com/livecycle/8.2/programlc/programmer/help/000264.html
Jasmin
Avatar
Level 2
try using the following instead of EJB
ConnectionProps.setProperty(ServiceClientFactoryProperties.
DSC_DEFAULT_SOAP_ENDPOINT, "http://localhost:8080"
DSC_TRANSPORT_PROTOCOL,ServiceClientFactoryProperties.DSC_SOAP_PROTOCOL
