I am programming pages with ColdFusion/Microsoft SQL in
Dreamweaver 8. On the page I am developing, I have bond information
(recordset rs_BondMaint) and payments for those bonds (recordset
rs_BondPaySchedule). I have the page set up so that it lists only
one Bond at a time (at the top) and then lists all of the payments
for that bond in a repeating region (at the bottom). The desired
result is for the bond payments at the bottom to only include
payments for the bond listed at the top (and when the user
navigates to another bond, the payments also update). How do I
connect the two (common field would be the bond ID number
(Bond_ID))?
I hear good things about the book "Teach yourself SQL in 10
minutes" by
Ben Forta.
You are asking the a very foundational question in how
RELATIONAL
databases such as Microsoft SQL work. The part you will want
to jump to
is how to JOIN two or more table together on one or more
common fields.
Hint...
You should not have two record sets, but rather one record
set with the
two parts related together.
It's not that simple. Both recordsets are built from multiple
table joins, but because of the layout it wouldn't do me much good
to join them into one. I actually got the first record to output
correctly using dynamic code in the SQL statement, but when you
click to the next record, the subdata does not update. Is there any
way to trigger the subdata to update when the main dataset changes?
Full code attached:
