1. Re: Transparant image printing with white backgroud in postscript file
pguerett May 19, 2009 5:43 AM (in response to jsriram)Do you get the image but without the white background?
Paul
2. Re: Transparant image printing with white backgroud in postscript file
jsriram May 20, 2009 2:43 AM (in response to pguerett)Hi paul,
I have issues in postscript file, the signature image is printing with white background and hiding the backdrop. I don't have issue in PDF output, it is printing with transparant image and it is not hiding the backdrop.
Sasi
3. Re: Transparant image printing with white backgroud in postscript file
pguerett May 20, 2009 6:41 AM (in response to jsriram)That is strange ......if it looks right in Acrobat it should print correctly. Can you post a sample and I will try it here.
Paul
4. Re: Transparant image printing with white backgroud in postscript file
jsriram May 21, 2009 8:16 AM (in response to pguerett)Hi Paul,
Attached sample xdp and signature. Pls do the needful.
Note: The problem occurs only when I render the form in postscript format. The output is fine when I generate PDF.
5. Re: Transparant image printing with white backgroud in postscript file
pguerett May 21, 2009 9:36 AM (in response to jsriram)The Forum does not allow adding of XDP files (yet!). There is also a problem with queueing of the files. Can you send the files to livecycle8@gmail.com instead?
Paul
