Adobe Presenter is unable to read the narration for this presentation.
Mar 20, 2009 Mar 20, 2009
I am using PowerPoint 2003 SP3 and when I try to use any Adobe Presenter menus, I get the error message:
The following file is incomplete or invalid:
C:\ ....... \Media.ppcx
Adobe Presenter must remove the invalid file to continue loading.
Adobe Presenter was unable to remove the file.
I am using Presenter 7.02
I have tried brand new presentations from blank templates in multiple folders.
Has anyone seen this error before?
Best regards
Colin Davis
Presenter
2.6K
May 20, 2009 May 20, 2009
Colin,
I am having the same issue, beginning today, using PowerPoint 2002 and Presenter 7.0.2.  It doesn't allow me to do anything under the Presenter menu.  If you find a resolution, please pass it along; I will do likewise.
Mark Handel
May 22, 2009 May 22, 2009
I am also having this problem but I upgraded the computer to Office 2007 and that didnt seem to help.  If I open the files on another computer it works fine.  I was going to remove Presenter and reinstall it and see what happens.  I will post my results.
May 27, 2009 May 27, 2009
Uninstall/reinstall of the presenter software fixed the issue!
Uninstalling and re-installing worked for me, too.  Now, back to work!
May 29, 2009 May 29, 2009
Hi
I am also facing  a similiar issue! I am using Microsoft PowerPoint 2007 with Presenter 7.0.2 Build 7464. Everything seemed to be working fine till I tried to open a slidedeck on my computer. This slidedeck was having the same traits i.e.it didn't allow to do anything under the Presenter menu.
Ever since, I opened this slidedeck on my PC, none of the functions on the presenter plug-in seems to be working. I get this error message for any click on the presenter plug-in: "Adobe Presenter is unable to open the narration in this presentation. The narration file for this presentation may be in use by another program or user, or it may be read-only. Try saving the presentation to a new file or location with File/Save As."
I also tried saving the above said file to a diffent location/ computer but none of this would work! I don't want to uninstall/reinstall presenter. Is there any other solution? Please help.
I tried recreated the system profile but that didnt help in my case.  If you really dont want to remove presenter I would try that.  If a new profile doesnt work the next step is to remove presenter and reinstall it.  It only takes about 5 minutes to uninstall/reinstall vs a new profile which could take hours depending on how much data you are moving...
Mar 30, 2020 Mar 30, 2020
Uninstall/reinstall didnt work for me neither....
Is there any other options?!?!?!?
Would anyone know what could cause this?
There were some errors in the Event Viewer, but nothing that would indicate the cause of this. they all seemed to be errors caused due to security.
The one that I found to be most relevant reads:
Event Type: Failure Audit
Event Source:     Security
Event Category:   Object Access
Event ID:   560
Date:       5/27/2009
Time:       7:45:13 PM
User:       <User ID>
Computer:   D-0745345A
Description:
Object Open:
      Object Server:    Security
      Object Type:      Mutant
      Object Name:      \BaseNamedObjects\ZonesCounterMutex
      Handle ID:  -
      Operation ID:     {0,7531028}
      Process ID: 3696
      Image File Name:  C:\Program Files\Microsoft Office\OFFICE11\POWERPNT.EXE
      Primary User Name:      <User Name>
      Primary Domain:   ENTERPRISE
      Primary Logon ID: (0x0,0x2E9E9)
      Client User Name: -
      Client Domain:    -
      Client Logon ID:  -
      Accesses:         DELETE
                  READ_CONTROL
                  WRITE_DAC
                  WRITE_OWNER
                  SYNCHRONIZE
                  Query mutant state
      Privileges:       -
      Restricted Sid Count: 0
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Help resources
