1. Re: Bridge Stacks
Omke Oudeman May 17, 2009 10:02 AM (in response to Mark A Goodwin)What am I doing wrong?
If I click on a stack to view - with the frame rate at it's lowest 23 - the
frame just whizz through I can't see them as they are too fast. Am incorrect
in thinking that I should be able to click on the stack and view watch frame
as if it was a mini slideshow?
Nothing, it does not work AFAIK. You can try to use the slider but I agree
that this is not accurate
If you want to see the content just click on the top file or on the icon
with the number of files that are in it. This expands the stack as well as
clicking on it does collapse them (or use the shortcut that shows under the
Stack menu)
Use the space bar or the Cmd B option to view them at full screen or in a
carousel.
Just use stacks for organizing the content panel, don't trust them to much
because for some unknown reason they can ungroup themselves at once. You are
not able to use filtering when in stacks etc etc.
2. Re: Bridge Stacks
Mark A Goodwin May 17, 2009 10:30 AM (in response to Omke Oudeman)Many thanks for the reply Omke,
I still can't figure why Adobe should include such a feature if it is basically just a 'grouping' feature and nothing else. I think Bridge an excellent piece of kit and I am looking forward to upgrading to CS4 in the neat future.
However, I am having a number of problems with it not performing as required recently. In many cases if after flipping out of to do something else, when I go back it does not respond to the mouse click, or the keyboard! I am seriously thinking about re-installing, but I am not that technical, and I don't want to screw up anything or loose any pictures etc.
I just feel it is not as good now as when I first installed. It's not a memory thing as I have 6 Gig, but there definitely some bugs in there.
Regards
Mark
3. Re: Bridge Stacks
Omke Oudeman May 18, 2009 2:33 AM (in response to Mark A Goodwin)I just feel it is not as good now as when I first installed. It's not a memory thing as I have 6 Gig, but there definitely some bugs in there.
That sounds familiar for Bridge CS3.
Here is what I did every now and then (in fact about every 6 weeks ):
For a real fresh start (meaning you loose all the cached previews before and also need to read all the previous saved cache to folder files)
Quit Bridge,
from the user library cache folder delete the Bridge Cache (cache / Adobe / Bridge CS3) and inhere move both files to the trash - they will refresh themselves with a new empty file after restart Bridge.
Also in the same user library preferences folder delete the AdobeBridge plist file (com.adobe.bridge2.plist)
Restart Bridge holding down option key and choose refresh preferences.
Reset preferences and workspace to your wishes and you have a very fresh start as if it was newly installed (but depending on the amount of files and folders you will need some time to recache the files)
Well, I still would not call it 'excellent' for as it is now but I agree that it is a very nice application for use as a digital lighttable. I use it every day and am a big fan of it, CS4 is a much better version so you really should consider to upgrade. But the programmers for Bridge have still a lot of of work to do before we can call it Excellent....
4. Re: Bridge Stacks
Mark A Goodwin May 18, 2009 3:29 AM (in response to Omke Oudeman)Omke,
Once again, many thanks for your input, I will certainly try what you have suggested.
Regards
Mark
5. Re: Bridge Stacks
SG... May 21, 2009 10:52 PM (in response to Mark A Goodwin)Hi Mark,
The frame rate for Stacks is not intended for use as a slideshow. It is there to playback sequence images. If you want a slideshow for just the stacked files, you have a couple of options. You can manually scrub thru the images by click dragging the circle to the right of the play icon. Or you can select the complete stack (click the offset frame or the number icon) and then use the View> Slideshow command (cmd + L).
Hopefully that helps you out.
thx,
steve
6. Re: Bridge Stacks
Mark A Goodwin May 22, 2009 9:01 AM (in response to SG...)Thanks Steve,
Maybe I didn't make myself clear enough.
It's not that I want to use the stack as a slide show. It's just that I couldn't work out what the feature was supposed to be doing. No matter how many or few pics I have in the stack, there is nothing I can get from clicking the little 'doobry' at the top of the stack, other than the quick fly past!
Cheers
Mark
Sunny Wales -UK
7. Re: Bridge Stacks
SG... May 22, 2009 1:20 PM (in response to Mark A Goodwin)Hi Mark,
In your OP you mentioned frame rates and mini-slideshow, which is why I took the slideshow tack.
The Stacks feature can provide a few things, and the playback 'scrubber' element is not meant to be all encompassing. It is really just a sub-element to allow our DVA customers a way to preview collections of frames in an image sequence.
Stacks in a still image/graphic workflow can be used to collect mulitple images for HDR, or panorama stitching in Ps without having to store them in a nested folder. Or a way to organize similar burst shots and only display the hero selection. Or a quick way to isolate subsets of images in a folder for batch metadata processing. Or a way to isolate a range of photos from sorting on the folder sort criteria.
Stacks is really just a UI treatment for content viewing in Bridge, and does have some fragility which makes it less useful in some workflows. It works well if the stacks stay in the folder where they are created, or elements of the stack are moved between folders. it doesn't work to move whole stacks between folders though.
CS4 has an Auto-Stack feature which will use camera data to collect images which are appropriate for HDR or panoramic stitching and stack them together for further processing in Ps.
http://help.adobe.com/en_US/Bridge/3.0/WS3B0804D4-9DB7-441d-983D-0F863872F6E6.html
Cheers,
steve
8. Re: Bridge Stacks
Ramón G Castañeda May 22, 2009 6:00 PM (in response to SG...)SG... wrote:
…our DVA customers a way to preview collections of frames in an image sequence.Steve, I'm baffled and curious. What's "DVA"?
Acronym Definition DVA Department of Veterans Affairs DVA Deutsche Verlagsanstalt (German publishing company) DVA DatenVerarbeitungsAnlage DVA Defence Vetting Agency (UK) DVA Dundee Voluntary Action (Scotland, UK) DVA Diverse Vector Area DVA Direct Vertical Access (Oil Industry) DVA Designated Viticultural Areas (wine regions) DVA Detector Vacuum Assembly DVA Dilated Vestibular Aqueduct DVA Deer Vehicle Accident DVA Design, Verified and Assigned DVA Direct Voltage Adapter DVA Dedicated Vendor Advocate DVA Doc Valentine Advertising DVA Deflecting Vane Anemometer DVA Dynamic Vocoding Allocation -
9. Re: Bridge Stacks
Mark A Goodwin May 22, 2009 6:25 PM (in response to SG...)Steve,
Thanks that does make a lot of sense. One thing I have been also doing, is swopping stacks in between folders, so that would obviously confuse things as well.
Thanks again
Mark
10. Re: Bridge Stacks
SG... Jun 22, 2009 6:38 AM (in response to Ramón G Castañeda)Sorry Ramón,
I've been meaning to come back here. You clicked the wrong Google link ;-)
Driver & Vehicle Agency
Digital Voice Announcer
Danish Vietnamese Association
Driver and Vehicle Agency
Deptartment of Veterans Affairs
Digital Voice Announcements
Documented Value Added
Delaware Valley Aviation
Developmental Venous Anomaly
Digital Video Authenticator
Distribution Video and Audio
Dave Vaughn and Associates
Dave Vosper Associates
David Voorhees Audio
Dean Village Association
Deborah Van Auten
Defence Veterans Association
Deferred Variable Annuity
Delaware Valley Academy
Delaware Volleyball Academy
Delta Virtual Airlines
Dental Ventures of America
Department of Visual Arts
Dept of Veterans' Affairs
Desert Valley Appraisers
Deutsche Verlags Anstalt
Dhu Varren Associates
Diamond Valley Archers
Digital Video and Audio
Digital Video Archive
Digital Video over Analog
Digital Vision Announces
Digital Voice Announcers
Director of Veteran Affairs
Disabled Veterans Associations
Distance Vector Algorithm
Distribution Video & Audio
Division of Virulence Assessment
Dollar Value Averaging
Domestic Violence Act
Domestic Violence Agency
Domestic Violence and Abuse
