This could one of two things. Firstly if the zip and CHM file are on a network drive you won't be able to see the contents. Extract to a local drive and see if that works. See here for the reason why. If it is on a local drive, you may need to unblock it. Click here to see how.
Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
The .chm file was downloaded to my local drive in a zipped file. When I open
properties, there is not an unblock option. What am I missing? Thanks, K
see attached screen print
I think you may have inadvertantly forgotten to attach the file
sorry..here it is
This is like a Christmas pantomime. All together folks, oh no it isn't.
The direction I see here is way beyond my expertise but I am going to give
it a try. Gads! I just need to get some work done, I know you've all been
there.......... There is no network or IT dept to deal with so I will try
the simpler remedies for a start. Thanks for the direction
If you use the camera icon on the post to add your image file that will enable us to see what you are.
I posted the screen print in the support message now. Thanks!
I used the following method and it worked! Thanks for your help.
In the File Download dialog box, click Save, and then choose where you
want to save the .chm file. Then, use one of the following methods:
Method 1
1. Double-click the .chm file.
2. In the Open File-Security Warning dialog box, click to clear
the *Always
ask before opening this file* check box.
3. Click Open
Hi there
Does this mean that before you were clicking a link to a CHM on the web, then simply attempting to run it from there without downloading it? If so, that would certainly explain things.
Cheers... Rick
I used the following method and it worked! I intend to use your site for
future reference. I was originally introduced to it by Rick Stone.
Thanks for your help. K
want to save the .chm file. Then, use one of the following methods: Method 1
the *Always
This is the screen print of the properties
