1. Re: E-mail Still Borked
Kath-H May 25, 2009 11:22 AM (in response to S.D.A.)Yup.
Diagnostic-Code: smtp; 553
<clearspace-1000355156-38842-2-1987865@mail.forums.adobe.com> address
unknown.
2. Re: E-mail Still Borked
Mark A. Boyd May 25, 2009 1:06 PM (in response to S.D.A.)Confirmed here.
As far as I'm concerned, they can keep it that way until the email system is actually ready for two-way correspondence.
To me that means that in addition to supplying normal email headers, it should treat quotes, code blocks, links, subject header, etc. in a consistent and predictible manner. Without munging the message or the code. If they're going to use some wiki-style notation, limit it to specific keywords, do not treat everything between square brackets (and other symbols) as something that should be translated. And it should NOT edit anything inside code blocks!
Not sure how I feel about inline images or attachments at this time. I guess for attachments, they should either kill the virus checking queue or reject all attachments - and delete the Attach Files feature in the Web interface.
At this point, the email notifications are exaclty that. Notification that somebody has replied to a thread/forum you're subscribed to. It is not meant as a means to participate with a reply, just as a link you can use to read the actual message - and it can be used to pick up where you left off in a long thread.
I ammended a line to my sig recently to reflect this opinion. And yes I still use a sig in other forums.
Mark A. Boyd
Keep-On-Learnin' :-)
If you are reading this via email, be aware that it may not be an accurate representation of my message. Login to read the actual message and/or to reply. -
3. Re: E-mail Still Borked
Christian Davideck May 25, 2009 6:03 PM (in response to Mark A. Boyd)Confirming that e-mail reply doesn't work for me either
Adobe shouldn't ask users to e-mail back, saying it is the "recommended method", when it doesn't even work (and users even have to retype a lost, lenghty answer in the worst case!)
To post a reply to the thread message, either reply to this email (recommended) or visit the message page:
4. Re: E-mail Still Borked
kanguyen May 25, 2009 5:41 PM (in response to S.D.A.)Hi all - thanks for reporting this.
I've logged a priority 1 case with Jive Support and they should be responding shortly.
I truly apologize for this. If I am feeling frustrated, I can only imagine how you guys feel.
I'll post an update once it's available.
5. Re: E-mail Still Borked
Christian Davideck May 25, 2009 6:05 PM (in response to Mark A. Boyd)To avoid this situation:
"If you are reading this via email, be aware that it may not be an accurate representation of my message. Login to read the actual message and/or to reply."
... wouldn't it be necessary to send out a new e-mail notification after message changes via the web interface ?
6. Re: E-mail Still Borked
What a refreshing attitude... Kanguyen and John C are like cheese compared to the chalk that are some other Adobe employee posters.
7. Re: E-mail Still Borked
Mark A. Boyd May 25, 2009 8:49 PM (in response to Christian Davideck)Christian Davideck wrote:
"If
to reply."... wouldn't it be necessary to send out a new e-mail notification after message changes via the web interface ?
For edited messages, you're right. And I don't actually expect such edits to be re-sent to everybody subscribed to the thread/forum. However, what goes out in emails even for unedited messages is not accurate. Links within the forum or to other forums are often stripped.
I don't know if it is still happening, but is the following hyperlinked in your email notification? Posting code in this forum or is it stripped down to */thread/427712* ? That particular link cause a bunch of round-about messages until I finally figured out that the recipient never saw a link to click on in his email.
Of course, I can send the full URL instead, and I have not seen any problems with doing that. But that does not change the fact that the Jive email system modifies both incoming and outgoing email messages such that they are not accurate representations of the messages that were sent or posted online.
8. Re: E-mail Still Borked
9. Re: E-mail Still Borked
Jochem van Dieten May 25, 2009 11:16 PM (in response to kanguyen)kanguyen wrote on 2009-05-26 01:41:
Email is working now.
Jochem
Jochem van Dieten
10. Re: E-mail Still Borked
Christian Davideck May 26, 2009 3:33 AM (in response to Mark A. Boyd)Mark A. Boyd wrote:
No link in my e-mail notification.
11. Re: E-mail Still Borked
Christian Davideck May 26, 2009 3:36 AM (in response to Jochem van Dieten) -
12. Re: E-mail Still Borked
Christian Davideck May 26, 2009 3:38 AM (in response to Christian Davideck)Christian Davideck wrote:
just trying to see if e-mail reply works...
test
OK, yes, e-mail reply does indeed work now.
But ... new problem: It took my first few words and made a link of it (which takey you nowhere ... error-message)
13. Re: E-mail Still Borked
Christian Davideck May 26, 2009 5:30 AM (in response to Christian Davideck)Is there a way to add quotations into our text, when we type our replies via e-mail ?
14. Re: E-mail Still Borked
JayJhabrix May 26, 2009 6:17 AM (in response to Christian Davideck)Christian Davideck wrote:
I would presume you just use the quotation marks....
15. Re: E-mail Still Borked
Christian Davideck May 26, 2009 6:22 AM (in response to JayJhabrix)[test via e-mail]
ok, thanks for the tip.
"I would presume you just use the quotation marks...."
[/test]
EDIT: no, doesn't work
16. Re: E-mail Still Borked
kanguyen May 26, 2009 6:36 AM (in response to kanguyen)As Jochem mentioned, the reply by email issue should be fixed now.
17. Re: E-mail Still Borked
Christian Davideck May 26, 2009 8:40 AM (in response to kanguyen)As Jochem mentioned, the reply by email issue should be fixed now.
Yes, many thanks !!
There are still formatting issues though. For example you MUST NOT write plus signs. If you type this
via e-mail:
(7500x4500,16bit,10+MP raw SMO, hitting CTRL A+D after moving)
you get this on the web:
(7500x4500,16bit,10MP raw SMO, hitting CTRL AD after moving)
And when you use [square brackets] you create links, that's intended ?
Is there any format guide, as to what special characters will do in e-mails ?
18. Re: E-mail Still Borked
S.D.A. May 26, 2009 7:50 AM (in response to Mark A. Boyd)It appears to be fixed. At least in the sense that my response to an earlier
post wasn't returned. Whether it shows up in the web interface is another
thing. Hopefully the 'repeater' bug is fixed !
Best Regards,
Steve
19. Re: E-mail Still Borked
S.D.A. May 26, 2009 8:21 AM (in response to Mark A. Boyd)It appears to be fixed. At least in the sense that my response to an earlier
Best Regards,
Steve
20. Re: E-mail Still Borked
Ramón G Castañeda May 26, 2009 8:27 AM (in response to S.D.A.)S.D.A. wrote:
…Hopefully the 'repeater' bug is fixed !Nope. You're repeating again.
21. Re: E-mail Still Borked
S.D.A. May 26, 2009 8:27 AM (in response to S.D.A.)O OH Not the repeater bug again ... <SIGH> (via web interface)
22. Re: E-mail Still Borked
S.D.A. May 26, 2009 8:52 AM (in response to kanguyen)Some (not all) of my e-mail posts are repeating again as you can see in this thread.
I'm wondering if it's how I reply to a thread (as not all are repeating). For example how does one allow for quoting attribution when responding via e-mail ? I guess a 'how to' for e-mail responses and new posts is needed ?
23. Re: E-mail Still Borked
kanguyen May 26, 2009 8:51 AM (in response to S.D.A.)S.D.A. - part of the deployment this weekend was to add additional logging to help troubleshoot the repeater bug. Hopefully all the echoing you're doing will help us figure it out. Thanks for your continued patience!
24. Re: E-mail Still Borked
S.D.A. May 26, 2009 8:54 AM (in response to Mark A. Boyd)It appears to be fixed. At least in the sense that my response to an earlier
Best Regards,
Steve
