Problem generating PDF using LifeCycle Designer ES
Avatar
Level 1
I am facing one problem while creating PDF using life cycle designer tool.
I am trying to generate a PDF that will contain a simple textInput with some text. I am using a snapshot class to capture this component.
This captured image is converted to base64 using base64Encoder.Now, this encoded string creates a problem with lifeCycle Designer..
If I enter,say 7, in textInput, the PDF gets generated properly with a complete snaphot of text box and the text within. But if I enter some other text, say XXDD, the PDF generation fails. Is there any problem with decoding the base64 encoded string?
Here is some code snippet :
On printing the value of the node <imageField> gives me data like:
         iVBORw0KGgoAAAANSUhEUgAAAN4AAAA4CAYAAACSekYo.// this is Base64 encoded string. For this case the PDF generation is successful, but if the string contains some spaces in between, the PDF generation fails.
Please suggest!
1 Reply
Avatar
Level 1
Hi All,
The problem has been resolved.
One learning: Never use the GET request method when passing the such huge data.
//Flex code
**********************************Instead of*****************************************
var url:String = "/pdfSampleApp";
        var snapshot:ImageSnapshot = ImageSnapshot.captureImage(uname);// uname is a textInput
        containerImage = ImageSnapshot.encodeImageAsBase64(snapshot);
        url = url + "/PDFGeneratorServlet?xmlData="+xmlImageModel";
         navigateToURL(new URLRequest(url), "_New");
********************************Use*****************************************************
var req : URLRequest = new URLRequest(url)
             var params : URLVariables = new URLVariables();
             params.xmlData = xmlImageModel;
             params.type  = type;
             req.data = params;
             req.method = URLRequestMethod.POST;
              navigateToURL(req,"_New");
Rest remains the same!
Cheers!
