Hi Frankone,
Can you verify if you are using a RealTek or RealTek High
Definition audio card? You may check it under the Device Manager.
To access the Device Manager, please do the following:
1. Right click on My Computer and select Properties.
2. Select the Hardware tab.
3. Select the ‘Device Manager’ button.
4. Scroll down to Sound, video, and game controllers and
click on the plus sign. This will display all of your sound
devices. Please make sure there is no red x or question mark next
to the devices.
If a RealTek or RealTek High Definition audio card is
present, that is most likely what’s causing the issue. There
is a known issue in Breeze Presenter with this sound card; it
causes Breeze Presenter to crash when recording audio for a
presentation. Currently R&D is looking into this issue and
working to find a solution. To work around the issue, you can try
to use a different soundcard.
We have a Tech Note about this issue which you might want to
refer to:
Recording audio using a RealTek soundcard freezes or crashes
Breeze Presenter
http://www.adobe.com/go/b9082845
I hope this helps.
