Matching tags highlighting
Aug 27, 2008 Aug 27, 2008
I've been waiting for years for Dreamweaver to have this option, does anyone knows if there's an option or an extension to activate this very helpful option? When you click on a <div> it will highlights it as well as its closing </div>, same thing for all tags.
I'm using PSPad (freeware) just because of this functionality that is so helpful. I can't believe Adobe never thought of it, even in CS4 I couldn't find it.
Please let me know if you are aware of such a function.
Thanks a lot.
23.8K
On Wed, 27 Aug 2008 23:54:43 +0000 (UTC), "MReaction"
>it.
> Thanks a lot.
In the bar just below the code window, click on an opening tag and its
matching closing tag and everything in between will be selected.
Win
Win Day
Wild Rose Websites www.wildrosewebsites.com
winday@wildrosewebsites.com
Aug 28, 2008 Aug 28, 2008
Thanks, I didn't know that, it's better than nothing but is there an option that does this automatically, no need to click anywhere and that highlights only the tag not the entire page and it turns red when there's no closing matching tag?
There is a function that will highlight (in yellow) code errors found in
code view. Look on the code view toolbar to find that one.
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"MReaction" <webforumsuser@macromedia.com> wrote in message
news:g96plo$d35$1@forums.macromedia.com...
> option
> highlights
> matching tag?
May 27, 2009 May 27, 2009
The answer is: You can't do it.
Not sure why Newsgroup_User has replied twice with answers that are not solutions at all!
Finding a matching tag in an HTML editor should be a standard and basic function. Has nothing to do with code validation. Sometimes you just want to see where a tag begins and ends. When looking at a closing tag, you might just want to see which opening tag it belongs to. On large HTML files, it can be a challenge to see what belongs to what.
In homesite, you would just click CTRL-M on any tag, opening or closing, and it would jump to the matching tag and highlight it. VERY useful as you're coding. It has nothing to do with validating and checking the document as a whole - which would come at the end. It's purely a visual aid, as you go, and a very useful one at that.
May 28, 2009 May 28, 2009
Newsgroup user actually gave the answer.  Click within the tag pair, and select the tag name on the tag selector bar.  The opening and closing tags and all content between will be highlighted.  What I'm puzzled about though is why you chose to respond to this nearly 1-year old post.
Jun 04, 2009 Jun 04, 2009
Ok, so that does work, as clumsy as it is, I never noticed this code bar thing, and that it could be clicked. But this solution still lacks a keyboard shortcut. There's no way I'm going to be clicking the tiny tag names in the code bar just to find a matching tag! Clicking the wrong tag accidently, means you lose your place in the code. There must be a better way.
And there is. I have since discovered the "select parent tag" function under the Edit menu, or CTRL [. This is a much easier and quicker way to find the matching tag.
Dreamweaver is therefore off the hook on this issue. Although, both ways still don't jump you to the matching tag, so highlighting everything in between will have to do, even though I have no need for everything in between to be selected. Still prefer Homesite's CTRL-M for the literal interpretation M for 'Match'.
Year old post? So what? Better to reply to an existing unaswered topic than create a new one. Status is "possibly answered" anyway.
Feb 17, 2011 Feb 17, 2011
Thank you fizz for the thoughtful response!  I've been using CTRL + [ since I read your post and it was the only thing keeping me from using dreamweaver at the time.
Honestly I still find this a disadvantage and would prefer to see the closing and opening tags highlighted automatically when you click on them or when your insertion mark is on the tag.  It saves a lot of time in the long run and I also can't believe adobe did not think of it earlier. Let's go Adobe!
Also I'd like to add that in some documents, such as XSL's in CS4 - the option to click the tag name at the bottom of the window is not available.  The only consistent solution I have found so far is the CTRL + [ method.
Feb 18, 2011 Feb 18, 2011
I've moved onto Notepad++ now as my primary HTML editor. Funnily
enough, even that didn't have the jump-to matching tag feature without
installing a plugin. It has highlightling as Dreaweaver does, but not
jumping to the matching tag. Luckily, the plugin was easily
available, can install from within Notepad++ and now to jump to the
matching tag I just press CTRL-T, which is what you want!
Just to clarify all this, the OP only wanted highlighting of matching
tag, which Dreamweaver does, so case closed on that. But my point was
that jumping to the matching tag in even better, done in one step with
a shortcut key is very useful. Often, for example, you want your
cursor at the point where the current div ends and the next one
starts. Hence finding and jumping to the matching tag in one step is
so useful as you edit. It's amazing that most HTML editors don't do
this. Homesite did it. Notepad++ does it after you install the plugin
called "HTML Tag".
Guest
Nov 21, 2012 Nov 21, 2012
I have to necro bump this...
Where is dynamic tag highlighting in CS6??  It's been four years...
Mar 25, 2013 Mar 25, 2013
I am very surprised that this is not in new CS6...
Matching tags/brackets highlighting on click very necessary thing in manual hard code.
Stay on pspad and do not buy dream, sorry adobe. Not make functions that are in the other editors for past year's - not good.
Apr 28, 2013 Apr 28, 2013
Same there!
Its a shame. We could make a chance.org petiton. Maybe it will help? Adobe please can put the tags highlighter? Your competitors put it.
Gosh, such an old discussion from 2008 no less!
In Code view, Select Parent Tag. See Screenshot.
Nancy O.
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Select Parent Tag has been discussed further up in the thread but what's being requested is automatic highlighting of the closing tag when you click on any opening tag.
Homesite and Notepad++ have it. Would be a useful addition to Dreamweaver.
Yes! Its a bit more helpful for hardcoders
It's not the same Nancy O.
Apr 29, 2013 Apr 29, 2013
She was right about one thing though...we have been waiting for over 5 years for some basic features.   Luckily there are some great alternatives out there...
Jun 13, 2014 Jun 13, 2014
Yes... Dreamweaver fails on so many basic levels, it's astonishing.
Mar 26, 2015 Mar 26, 2015
In Dreamweaver CC 2014, go to Edit > Preferences > Code Coloring - Check the Enable tag highlighting box. Boom!
