Delay Between Text to Voice Conversion
May 28, 2009 May 28, 2009
Hi friends
Here i have small clarification about, text to voice conversion. When i work with Text to voice conversion in my training video, i have noticed that, there is no option is available to leave the interval between text to voice conversion in a same slide. Is there any options available to maintain the delay between Same slide text to voice conversion?
Expecting solution to this issue.
Getting started
1.5K
Community Expert , May 28, 2009 May 28, 2009
OK, have a look at the blog I indicated. It is possible to insert pauses in the slide notes which will be converted to Speech. An example they give:
<vtml_pause time="1000"></vtml_pause>
will introduce a pause of exactly one second in the speech.
I'm not sure to understand your question completely, but could one of the blogs http://blogs.adobe.com/captivate/2009/04/ of april  about "VTML tags in Text to Speech !" help you?
Hi
thanks for quick response. What i mean is, for example i have slide with 15seconds long. With this slide i am using text to voice conversion. For first 5 seconds i need text to voice conversion. Next five seconds i does not need any voice in that slide. Again last 5 seconds i need voice again using text to voice conversion. How can i leave break between first and last 5 seconds audio. Does this make sense to you? Hope it will. Anyway i will check the blog post now to get solution for this issue.
Lilybiri
You scored 10 Marks. Great solution for my issue.This answer is must be sticky.
Need one more help. How can i add watermark or logo in all slides automatically means not manually inserting each and every slide.?
No thanks, those are due to the blog specialists...
Your next question is quite simple: insert the image (watermark or logo) on the first slide. Open the properties menu, go to the sheet 'Options' and under Timing choose to display 'for the rest of the project'. Eventually change the transition which is standard 'Fade in and out'. Be sure to have the image with the right dimensions. Personally I prefer the PNG24-format.
I love your quick and effective answers. Thanks mate. I will catch you soon with more questions.
Sorry, double post
Help resources
