Recording keystrokes in Captivate 4
May 29, 2009 May 29, 2009
I seem to be having trouble getting keystrokes to record with Captivate 4. In the Preferences dialog, under Recording > Settings, the Keystrokes box is checked. After I come back to Captivate from recording, no text appears where I typed nor is there a text object in the timeline for that slide. Any help would be appreciated.
Recording
1.8K
Deleted User
Jun 02, 2009 Jun 02, 2009
Hi Sean,
Actually, during Automatic recording when you type something, Captivate relies on the information yelled by the system to generate relevant objects. But in case of VM this "yelling" does not reach to captivate if captivate is installed on the base system and NOT on the VM.
So I would advise you to please install Captivate inside your VM. Hopefully this would resolve your issue.
Manish
http://blogs.adobe.com/captivate
Hi there
Was the project recorded using Full Motion Capture?
If so, the keystrokes are part of the Full Motion clip and won't be on the Timeline.
Cheers... Rick
No, the project wasn't originally recorded using FMR. I tried going back and inserting FMR recordings but I didn't see the text in those slides either. Not sure if it matters or not, but I'm using Captivate on Vista.
Hi again
Vista shouldn't be an issue unless it's the 64 bit variety. We have seen lots of oddness on that flavor.
If that's what you have, sorry but the best I can offer is to have you report to Adobe as a bug.
Click here to visit the Wish Form/Bug Reporting Form
Cheers... Rick
Jun 01, 2009 Jun 01, 2009
I'm not on the 64bit version. Should keystrokes record in automatic mode or just in FMR? I created a new test project and I can see the keystrokes in FMR but not in automatic mode.
Hi there
Keystrokes should be recorded as long as the option has been enabled.
Could be you are seeing a bug. Just in case, you should consider reporting as same.
Cheers... Rick
Guest
Hi Sean,
Few questions:
1. Whay key strokes are you trying to record?
2. What application are you trying to record?
Could you please brief me the exact steps that you are doing.
Manish
Hi Manish,
I'm building some training content on the software for the company I work for. So far, I'm loving Captivate and everyone else is loving the output but I can't seem to capture keystrokes during automatic recording. The application I'm recording is running inside a VM. To begin recording, I place the recording box around the application. There are several instances where I need to fill in some information on a dialog box that is pertinent to the training material.
Could the VM be an issue? Keystroke capture does work during FMR.
Sean
Guest
Hi Sean,
Manish
Manish,
Thanks so much for the input. I'll install Captivate on the VM and give that a try.
Help resources
