7 Replies Latest reply on Nov 2, 2010 4:13 PM by bbiceman
    Adobe Reader 9 highlights text when scrolling in terminal server
    mpaniak
      Running a terminal server with WIndow 2003.  Have Adobe 9 Reader installed.  When a pdf is opened, it will look correct.  However, when one uses the scroll bar on the right to see more of the document, text can be highlighted and change colors constantly when scrolling.
      Test it outside of terminal server and it works fine.  This issue did not happen with other versions of Reader.  I have attached two samples one clean and one highlighted.
      Any help is appreciated
        • 1. Re: Adobe Reader 9 highlights text when scrolling in terminal server
          Naishel
          Im having the same problem but with version 8.0.0. Im updating but not sure if this will solve the problem.
          If you select text and unselect sometimes it solve it, but scrolling again it highlight again.
          • 2. Re: Adobe Reader 9 highlights text when scrolling in terminal server
            Naishel Newcomer
            Hi again,
            Googling i've found a solution
            http://www.jasonslater.co.uk/2008/01/08/corrupt-text-display-in-acrobat-and-terminal-servi ces/
            "going into Edit -> Preferences -> Page Display -> and switching off Smooth Text in the Rendering group - the problem goes away."
            Thanks and i hope this solve your problem with version 9 too.
            • 3. Re: Adobe Reader 9 highlights text when scrolling in terminal server
              mpaniak Newcomer
              Thanks for your help.
              Unfortuantely those options aren't in Adobe 9.
              I did uncheck the smooth images and smooth line art option found in the same area.  No change for Adobe 9 however.
              • 4. Re: Adobe Reader 9 highlights text when scrolling in terminal server
                ErluUndomiel
                I have a custom deployment of Adobe Reader 9.1.3 and with certain PDF's it randomly highlights in various colors blocks of text.  Scrolling up and down alters the highlighted area semi randomly.  Printing the document is fine.  I should note that being logged in to the terminal server console or rdp into it these types of documents are fine.   When using a thin client (in this case a boundless capio) with a low color resolution capability the issue is present.  Using some other thin clients with a higher color/resolution capability do not have the issue.
                The stated workaround of Edit>preferences> Page display category> Rendering>smooth text  changed from default of for Laptop/LCD screesn to None does correct the issue for us.
                What I would really like to know however, is how to automate turning this off post deployment or even how to adjust this setting in building the deployment in the first place  (either through adobe customization wizard or through an msi editor like orca).
                Paul
                • 5. Re: Adobe Reader 9 highlights text when scrolling in terminal server
                  RichJWilson
                  Okay. Here is what I found. These settings are changed\saved under the User settings in the registry. Here is the key the changes are made to:
                  \\HKCU\Software\Adobe\Adobe Reader\9.0\Originals
                  When "NONE" is selected from Adobe Reader - Edit - Preferences - Page Display - Rendering, three DWORD values are added to the above mentioned registry key. These are:
                  Value Name - Value Data
                  bAntialiasText - 0
                  benableDDR - 0
                  iAntialiasThreshold - 12
                  I have added these lines to a login script that adds the necessary DWORD values to default the "Rendering" to NONE.
                  reg add "HKCU\Software\Adobe\Acrobat Reader\9.0\Originals" /V bAntialiasText /T REG_DWORD /F /D 0
                  reg add "HKCU\Software\Adobe\Acrobat Reader\9.0\Originals" /V benableDDR /T REG_DWORD /F /D 0
                  reg add "HKCU\Software\Adobe\Acrobat Reader\9.0\Originals" /V iAntialiasThreshold /T REG_DWORD /F /D 12
                  Cheers!
                  • 6. Re: Adobe Reader 9 highlights text when scrolling in terminal server
                    ErluUndomiel Newcomer
                    Very cool. Thanks for the info!
                    Date: Fri, 16 Oct 2009 10:42:24 -0600
                    To: strobel_paul@hotmail.com
                    Subject: Adobe Reader 9 highlights text when scrolling in terminal server
                    *bAntialiasText - 0
                    benableDDR - 0
                    iAntialiasThreshold - 12*
                    *reg add "HKCU\Software\Adobe\Acrobat Reader\9.0\Originals" /V bAntialiasText /T REG_DWORD /F /D 0
                    reg add "HKCU\Software\Adobe\Acrobat Reader\9.0\Originals" /V iAntialiasThreshold /T REG_DWORD /F /D 12*
                    Cheers!
                    • 7. Re: Adobe Reader 9 highlights text when scrolling in terminal server
                      bbiceman
                      I'm using adobe reader 9.40 and have been dealing with this ever since I upgraded to 9.
                      The work around is go to Edit --> Preferences --> Page Display
                      than uncheck "Use 2D graphics acceleration"
                      than uncheck "Smooth line art" and "Smooth images"
                      Sure am glad that got resolved .... what a pain !!
                      b
