How can I log FDS?
Avatar
Level 3
Hi all
I'm having problems with Flex Data Management Service. But I
don't know if the problem is at the client.. the configuration
files or the Java classes!
Is there a way to help me finding the problem? logging or
something like that?
thank you
Avatar
Level 1
I always have a working sample application on the server.
Whenever I add a new destination to the data-management-config.xml
file, I make sure the sample application still works. If it's not,
the problem may caused by the configuration file. Javs classess
should be easy to test using unit test.
Avatar
Level 3
Thank you..
but how to test the Java files? how can I be sure that the
method is being found? it's complicated
Avatar
Former Community Member
You can turn on Flex server side logging. Search for logging
tag in services-config.xml
