You need to change the title in your Window Properties. Double click on your window and you'll see the old title.
Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
Hi there
If WebHelp is your output, click File > Project Settings and adjust the Project Title field.
If CHM (Microsoft HTML Help) is your output, as Colum indicated, you edit the properties of the CHM window. This means you need to locate the area where you configure the window. Exactly where this area is found will depend on your RoboHelp version.
For version 6 or earlier (The Adobe version 6) you will find a folder in your Project Manager that is labeled Windows.
For version 7 or 8, you need to first open the Project Set Up pod (View > Pods > Project Set Up)
Expand the Windows folder and edit the Window settings. Specifically, the Window Caption area.
Cheers... Rick
