Hi guys - can anyone help?
I'm having a look at cp4, looking to potentially upgrade, but have come up with a query. In cp3, if I build mulitiple SCO's I navigate between them either through the final interaction in a SCO or through the menu. It appears that the new TOC doesn't permit selection of navigation options so am I limited to interaction based "Open URL or file"? Seems something of a backward step if thats the case.......
Robbie
Hi there
Please note that there are lots of places where you might use the "Open URL or File".
Which are you referring to?
Cheers... Rick
Hi Rick
Aware of those, exactly the same as cp3, but I've been using this functionality within the menu to provide as seamless a navigation as possible to move back and forth between different SCO's; has this functionality now been removed? If so it appears to be a big step backward.
TIA
Robbie
Hi again
Ahhh, okay. You want to do it via the menu.
Still possible but you have to think differently now. What you do now is to configure a slide with an on Enter event triggering the URL. Then you have that slide in the Menu where it is linked to.
Cheers... Rick
Click here to visit the Wish Form/Bug Reporting Form
Thanks Rick
I new there'd be a way just a matter of posing the question correctly
I'll give it a go
Robbie
