"Please enter the Project title here" is all that's displaying on my output. I've verified (and resaved & compiled) that the Project Title has been typed in the Project Settings.
Does anyone have any ideas????
Hi there
Annnnnd the output would be?
* CHM
* WebHelp
* FlashHelp
* Air Help
* Oracle Help
* JavaHelp
* Printed Documentation
Cheers... Rick
Gosh sorry. .chm
Sorry folks. The output is .chm.
Hey there
Okay see if the post linked below helps you solve it. It was answered a bit earlier today.
Cheers... Rick
Thank you. I am using RoboHelp X5 and I have no idea where the Windows folder is in the project, but I am going to look for it right now. Thank you very much!!!!
Hey there
See if the image below helps you find it.
Cheers... Rick
Actually, yes it did help. Thanks. I wasn't even looking "in" RoboHelp for it I was searching through the files where the output is stored. THANKS! Now, in that windows folder I only had one file and I added the title there, saved it and then batch generated but it's still not on the output...
Hi again
Okay, so we need to dig a bit deeper on this.
Note that there are two window types. You need to be working with the type that is meant for use with your output. Please reference the image below:
Make sure you are editing the window for your output!
Cheers... Rick
Interesting, I don't have a file type shown for the window...but the properties show that it's HTML Help. Even if I delete it and add a new window, I don't have the option to select a chm type window.
Hi again
Often in times like this it's just simpler to connect where I can view your screen and converse with you directly. Are you up for that? Shouldn't take long to fix it.
If you are open to that, shoot me a private message containing your phone number. I'll shoot back a link for you to click where we can connect and I can observe your screen while you work. Then I can coach you through some dialogs to see what's going on.
My email address is rstone75 (at) kc (dot) rr (dot) com
Cheers... Rick
