I am working with RH8 and have set up a merged project according to the Grainge new method. The following is the file structure for my project (working) files:
C
DocsandSettings
MyName
Mydocs
MyrobohelpProjects\
Help
Help file (this contains the redirect to SSHelp\Help.htm)
SSHelp
Children
Help
Main_Help_Page_files\Main_Help_Page.htm
Achild
A_Help\A_Help_files\A_Child.htm
EChild
EHelp\EHelp\EHelp_files\EChild.htm
I can link from Help to A_Child.htm. I cannot make the link from Help to Echild.htm
I generate to C\Merged\mergedProjects then the child files are all in their separate folders.
What Am I doing wrong?
Pat
That looks better. The XPJ will always be in the root folder for that project.
Download the example on my site. You will see it first hand that way.
The way you had things links between child projects should have worked and links between the parent and any child would have broken. Make sure you are creating the links they way I describe. The relative path is very important.
I'd rather see a screenshot.
Ok, i attached a file. Hope this help.
Pat
I got an error message trying to attache them. Here they are but these aren't very good.
Your structure is wrong.
You have the source child projects in a a folder that is within the parent.
SSHelp is the parent and that should be in a folder called whatever you want, let's call it AllProjects.
So you should have AllProject with two subfolders, one called SSHelp and the XPJ for the parent will be in the SSHelp folder. The other will be called children. At the moment children is in the parent project folder.
I don't recommend having your projects within My Documents etc. I know that is the RH default but it leads to long paths that can cause problems.
Ok, so let me see if I understand this. My help structure for working files should be like this --
All projects (folder)
Parent (folder)
ssHelp.htm
ssHelp.xpj (file that will have the redirect to Achild.htm)
Children (folder)
Help (folder)
MainHelpPage.htm
Achild (folder)
Achild.htm
Echild (folder)
Echild.htm
Should the Help, Achild and Echild folders also contain the .xpj files for those children?
Can I move the whole structure under C\RHWorking or will everything break?
In my current structure the Achild actually links. I wonder why??
Pat
I set up the new structure. However, it didn't help.
My starting file is a child called Help. Then there are children Ahelp and Ehelp. I have always been able to link the children Help and Ahelp. I cannot link Help to Ehelp.
I set the working file structures up exactly the same. I set the merged structures up exactly the same but nothing seems to work.
It's almost quitting time here so I hope I can think of something next week.
By the way, I downloaded your example but it won't run on RH8. It says it's converting it then nothing happens.
But thank you for your time and patience. You deserve a medal (nice bottle of wine, good meal, money) for the good work you do.
Pat
Visit Adobe's site where there is a later version of the article and a RH8 demo.
http://www.adobe.com/devnet/robohelp/articles/merged_help.html
I got the files to link!!!!!
Thank you for hanging in there with me.
I moved all the files around, created a new help on the C drive and linked everything. That seemed to do it. I'm guessing the files didn't know where they were supposed to go because my structure was such a mess. Once I straightened that out it worked.
Thank you so much for the links to your instruction files. I couldn't have done it without them.
Pat
