HELLO,
Is there any option in captivate to see the same slide again?
thanks, anat
Hi there
In the past we have accomplished this by inserting a slide immediately preceding the slide we want to play over. We time that slide for perhaps .1 seconds (the smallest possible time slice) then we just program a Button or Click Box to jump to that slide.
Cheers... Rick
There are multiple ways to do it. Please elaborate on what exactly you are trying to achieve. Then somebody can help you with a perfect solution.
One of the ways to display the same slide can be -
1. In the 'slide properties' dialog, look for navigation - on slide exit and set it as 'go to last visited slide'
Please explain your problem in detail. Different solutions might be possible then.
Mukul
Hi Mukul
Because I am building an e- learning program that includ a video and text anad animation at the same time,
I wanted to let the users see the slides again if they want to.
in the navigation it is posibble to go to all of the slides except the same slide, and this is my problem.
thanks alot, anat
Hi there
Cheers... Rick
Hi Rick,
Yes that what I consider, but it meens that I'll need to double my slides number.
I hope that there is better solution in the captivate for this issue.
thank you very much,
Anat
Hi again
Question here. Do you have Captivate 4? If so, you could do it using the new Variables and Scripting.
See if the link below helps you sort it (if you have Captivate 4)
Cheers... Rick
Hi Rick,
well I will not know until I'll have the 4 version,and I' am going to.
from your link I understand that we can do an advanced action,
although I really don't have any experience with it.
can you tell me rick, the exact action for the target of able all
of the slides repeat themselves , if the user need it ?
anat
