In LiveCycle 7x it is possible to make a process type to bahave as a Web Service.
Is there a similar option available in ES?
If your answer is 'create a SOAP endpoint', i have one more question on that:
1. SOAP endpoint will be automatically created. But need to know where to find the WSDL url for that web service?
for e.g in 7x we can see all the web services in the url http://localhost:8080/services. Whats the alternate in ES?
In 7x its very easy as we just need to check the 'Web Service' option in the Workflow Properties dialog. What about ES??
Thanks in advance
Nith
Total Likes
"Whats the alternate in ES?"
In ES the web services are located at : http://<servername>:<port>/soap/services/NameOfProcess?wsdl
Jasmin
Total Likes
I am getting an Internal Server error when i try to open the specific URL.
HTTP error code is 500.
Does it something related to problems in installation?
Nith
Total Likes
Can you paste your url, so I can take a look at the format?
Jasmin
Total Likes
my process name is Process1
so the url I tried is http://localhost:8080/services/Process1?wsdl
One more question is:
How will we differentiate a normal Process and a Process running as a Web Service?
Total Likes
You have the url wrong.
The url should be http://localhost:8080/soap/services/Process1?wsdl
"How will we differentiate a normal Process and a Process running as a Web Service?"
There is no difference. A process is a process. Web service is just a way to invoke that process. You can also use email, watch folder, Workspace, API, Flex Remoting, but that doesn't change the way the process works. Those are just different ways to start it.
Jasmin
Total Likes
I got answer for my question. Many thanks for that.
Also i tried the new URL and is woking fine (when i try to locate the WSDL) in the browser.
Still i have got one more issue.
When i try to call this web service from a PDF (using DataConnection), it is not working.
And when i try to test this web service using "Web Service" service, i'm getting the following error:
"Web Service is not in RUNNING state".
I ve confirmed that my SOAP end poing is enabled. What may be the problem??
Thanks in advance,
Nith
Total Likes
Is your process active? In Workbench, do you see a little green checkmark on the icon?
Jasmin
Total Likes
Are you using Acrobat or Reader to call the web service?
Paul
Total Likes
Again, the problem is caused in the evaluation version. In original version, this error is not coming.
Thanks a lot.
Total Likes
This issue is no more with the original version.
Nith
Total Likes
