I'm using Presenter 7.01
I cannot seem to add a video of a taking head to the Presenter Panel.
I can add video to the main slide no problem but there does not seem to be any option to add video to the top right panel and then display a presentation slide for the duration of the video.
If I go into the Slide Properties, and click on the Slide, the Edit button stays greyed out. I can only get the Edit button when I choose multiple slides, but then the options are limited.
Any ideas please?
Cheers
Adding THV is now done using 'Import Video' dialog. There is a small set of radio button to specify if you want the video on slide or on the the sidebar (top-left).
