1. Re: Variable DRIVERPATH is undefined Error
Cole May 31, 2007 7:10 PM (in response to abhishek77)CF probably does not have permission to access to your registry
Locate the following reg key
HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI\<your data source>\
do you see a string called "Driver"?
if not, create it with the value of "C:\WINDOWS\System32\odbcjt32.dll"
if this works, credit Rob D. -
2. Re: Variable DRIVERPATH is undefined Error
abhishek77 Jun 2, 2007 4:16 PM (in response to abhishek77)That does work. but has to be done each time an access datasource is added. Is there anyway to give coldfusion permission to access the registry automatically? -
3. Re: Variable DRIVERPATH is undefined Error
ssailer Aug 8, 2007 12:18 PM (in response to Cole)I did the exact same thing, but it's not working for me. I still get the following error:
Unable to update the NT registry.
Variable DRIVERPATH is undefined.
Any ideas anyone? -
4. Re: Variable DRIVERPATH is undefined Error
ssailer Aug 8, 2007 1:42 PM (in response to Cole)Thank you Rob D. :)
5. Re: Variable DRIVERPATH is undefined Error
jimmoos Jun 11, 2009 8:32 AM (in response to abhishek77)I had same problem with x64 vista found answer
Open C:\Windows\SysWOW64\odbcad32.exe and create a System DSN using the Microsoft Access Driver (*.mdb).
Then open the ColdFusion Admin and create a datasource using the ODBC Socket driver.
Check the Trusted connection checkbox and it should work.
6. Re: Variable DRIVERPATH is undefined Error
kkhisa Oct 3, 2010 9:33 AM (in response to jimmoos)@jimmoos
Your solution is clean and works! No messing around with registry entries.
I have x64 Windows 7. I took myself backwards and was able to reinstall my ColdFusion MX 6.1 software. It was also my first time to use the "ODBC Socket driver" option. Upto this point I had always used the other drivers (native ones)
Thx buddy
7. Re: Variable DRIVERPATH is undefined Error
Skydiver Jim Mar 20, 2011 11:02 AM (in response to kkhisa)Thanks so much for the info! I have Windows 7 x64bit with
Coldfusion 6.1. I'm just developing for myself so didn't want to upgrade. This solution worked perfectly. Thanks again!
8. Re: Variable DRIVERPATH is undefined Error
ssailer Jun 1, 2011 5:52 AM (in response to jimmoos)I'm having the same problem, but when I try to create a SYSTEM DSN, I don't have a Microsoft Access option. I only have SQL Server and SQL Native Client. Any suggestions? Thanks!
9. Re: Variable DRIVERPATH is undefined Error
aquarium.west Sep 1, 2011 11:42 PM (in response to jimmoos)That's a clean solution, but the MS Access DSN I add in System DSN does not show up in the "ODBC DSN" select box in the Datasource creation form in the CF Admin at
Data & Services > Datasources > ODBC Socket
so when I submit the form I get this error:
10. Re: Variable DRIVERPATH is undefined Error
frogstarr78 Nov 23, 2012 1:09 AM (in response to aquarium.west)I had similar issues. Fixed them by installing the 64-bit drivers from here: http://www.microsoft.com/en-us/download/details.aspx?id=13255
Then I had to add the System DSN in the 64-bit ODBC Management Console, which causes it appear in the ODBC DSN drop-down on the CF Admin Data Source form.
Then had to add the same System DSN to the 32-bit ODBC Management Console, to fix this error when CF attempts to connect to the database:
Connection verification failed for data source: PABasketballSSJ
java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
The root cause was that: java.sql.SQLException: [Macromedia][SequeLink JDBC Driver][ODBC Socket]internal error: The specified DSN contains an architecture mismatch between the Driver and Application
