4 Replies Latest reply: Dec 7, 2009 7:28 PM by Cheno1115 RSS
    CS4 installation problem: Flash/Dreamweaver/Fireworks won't open
    Tom Glen Community Member
      Hi, was wondering if anyone could help me. I'm installing Design premium CS4 on 32bit Windows Vista. The installation goes through seemingly alright but then when i try to open Dreamweaver, Flash or Fireworks it brings up an error message saying
      "The application failed to initialilze properly (0xc0150004)" with these details
      Problem signature:
        Problem Event Name:    APPCRASH
        Application Name:    Flash.exe
        Application Version:    10.0.0.544
        Application Timestamp:    48c73089
        Fault Module Name:    ntdll.dll
        Fault Module Version:    6.0.6002.18005
        Fault Module Timestamp:    49e03821
        Exception Code:    c0150004
        Exception Offset:    00009eed
        OS Version:    6.0.6002.2.2.0.768.3
        Locale ID:    2057
        Additional Information 1:    9d13
        Additional Information 2:    1abee00edb3fc1158f9ad6f44f0f6be8
        Additional Information 3:    9d13
        Additional Information 4:    1abee00edb3fc1158f9ad6f44f0f6be8
      All the other programs work fine, its just those ones that won't even open. I've tried reinstalling in every different way i can think of, without AV, with MS SQL and IIS switched off, from desktop with selective startup, you name it and it still has the same problem.
      Can anyone help with what might be causing the problem? not sure if its an installation problem or a windows problem (a setting or something) but i'd really appreciate any ideas anyone might have.
      tom
      Oh yeah, also when i look in install logs it brings up this error
      ERROR
      Log of: object
      isRunning {string}: 0
      percentComplete {string}: 100
      message {object}: [object Object]
      Log of: object
                  code {string}: 0
                  args {object}: [object Object]
      which i think refers to the installer freezing when checking the system profile on install but it seems to go through install alright. It also has the following errors.
      ERROR
      The payload with AdobeCode: {35304775-CB5F-101B-A142-83B5468C225C} has required dependency on:
                  Family: InDesign
                  ProductName: Adobe InDesign CS4 Icon Handler x64
                  MinVersion:
                  This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
                  Removing this dependency from list. Product may function improperly.
