1 Reply Latest reply: Jun 13, 2009 5:20 AM by Bill@VT RSS
    Saving / Priniting from HTLM files
    GESYMSB Community Member
      Hello folks, everytime I save as PDF a web page or Print the Web page
      My Acrobat 7 inserts the address on top or bottom.
      Like you see here : file:///E|/DVD Lab Pro v2.5/GUIDE/audiotitle.htm (1 of 2)6/13/2009 7:20:32 AM
      It also puts a little title on the very top of the page.
      How can I stop / Indicate my Acrobat 7 to NOT do that and just convert the page to pdf ?
                 Gesy
        • 1. Re: Saving / Priniting from HTLM files
          Bill@VT CommunityMVP
          If you use the FILE>Open Web Page in Acrobat, you will get a set of settings on the open page that allows you to set these features. You are using your browser and the settings you are using are set by the browser, not Acrobat. You would get the same result if you printed to paper. You can see the result if you do a print preview that would show how your browser would show the page. In SeaMonkey, this is all in the Page Setup. A Page Setup is also found in IE and Firefox. If you use Create PDF in IE, you might additional settings under the Adobe Preferences menu.
