Problem
Program Crash: Adobe RoboHelp 8 HTML
Suite: Adobe Technical Communication Suite 2 (TCS 2)
Description: program crashes as soon as I try to access the application's top menu - even before opening or creating a project. This crash occurs whether using the mouse (touchpad) or keyboard. (The "Alt" key alone will trigger a crash.)
Windows message: "Adobe Robohelp 8 has stopped working. Windows is checking for a solution to the problem ..."
Notes: 1) originally had TCS 1 evaulation then installed TCS 2;
2) reinstalling TCS 2 did not solve this problem.
Request
Please advise if you have had a similar issue and how it was resolved. I have reported this as a bug to Adobe.
Environment
Notebook PC: Toshiba Satellite Pro A300
Processor: Intel Core 2 Duo, 2Ghz
RAM: 4Gb
OS: Windows Vista Business, Service Pack 1
Updates: Windows and Adobe applied up to Jun 16, 2009
Windows application log reports the following application error:
Faulting application RoboHTML.exe, version 8.0.0.203, time stamp 0x4944f3bb, faulting module OLEACC.dll, version 4.2.5406.0, time stamp 0x4791a74d, exception code 0xc0000005, fault offset 0x00004170, process id 0x62c, application start time 0x01c9eecf04239e25.
Hi there
Is this Vista 64 bit? If so, have you tried running in 32 bit mode?
I don't think we have seen an "Adobe Approved" version of RoboHelp for Vista 64 bit to date.
Cheers... Rick
It is a 32-bit operating system.
Have solved this one - notes are here for anyone with similar problem.
The hint of OLEACC.dll led me to try likely suspect processes - and de-activating PwdBank.exe was what restored Robohelp access. Further reading led to the Toshiba support website, where PwdBank was associated with problems in TrueSuite Access Manager. My current version was 2.1.14.0. I upgraded (uninstalled old, installed new) to the latest version (2.5.29.0) and the problem is no longer occurring.
