3 Replies Latest reply: Jun 17, 2009 12:10 PM by RndmPplPrsn RSS
    PE7 Trial
    RndmPplPrsn
      Yes I know its the tiral, and I'm not sure what parameters are exactly cut from the trail compared to the full version, but I have two issues.
      I have been looking for new software and I have come to like this the best, compared to PE 3. I had also liked Vegas Movio Studio.......9, because it seemed very stable, until they both started to give me errors.
      I have had a memory problem in the past with PE 3, among other things, and glitches like this is the reason that I needed to upgrade.
      My two problems, is one, I have AVI files that are read only as audio files in PE, yet they work completely as video outside of it. I had this problem with the third one, but I didn't have the codec then, but now I am sure I do.
      My other problem is PE keeps saying I'm running low on memory, and I just did the fix for it (IncreaseUSerVA and /3GB Options), I have 4 GB of RAM total, and I'm getting this message when my entire system is only using 2GB of RAM.
      Its not the rest of my PC either for I have 250 GB SATA HDD (Internal), 1TB External SATA HDD (external), 3.0 GHz Dualcore AMD CPU, NVIDIA 9800 GT Video Card (512 of RAM), and the 4GB of RAM I had mentioned earlier.
        • 1. Re: PE7 Trial
          Steve Grisetti CommunityMVP
          My guess is that your source video files are at the core of all of your problems.
          AVIs are not all the same. DV-AVIs are the ideal format for editing on a home computer, and these are the files that come from miniDV, tape-based camcorders.
          Other video formats -- like video from still camera -- can use any of a number of codecs, most of which cause the very symptoms you describe. A good indication is a red line that runs along the top of the timeline as you add these files to your video project.
          Where did these AVIs come from?
          • 2. Re: PE7 Trial
            Bill Hunt CommunityMVP
            You might want to take a look at this ARTICLE in the Tips & Tricks section. Much might well be answered in it.
            Good luck,
            Hunt
            • 3. Re: PE7 Trial
              RndmPplPrsn Community Member
              WellI solved the issues.
              It seems that Adobe just issues that the memory is running low, but its fine.
              And for the avi issues, I use G-Spot, that how I know I have the codec, it appears that the Vegas Trial created additional sound files in the directory, so when I loaded all of the files into PE 7 there were spaces with no files there (At Media Import), but apparently it was those additional sound files. Sorry for the false alarm, as I was also looking in the semi wrong place for files.
              Thanks anyways.
