I am using a variable v_Name that is entered in a text box in the beginning of my program so that at the end of the program it is included in a certificate from a widget.
The next screen after the text entry box includes the v_Name variable in a caption. The caption is within a box designed for a membership card.
The name appears fine in the box.
I then use a button to execute a javascript to print the membership card.
I have used the command window.print() within the execute javascript within the button properites. But nothing happens. The print dialog box never opens. Is this the correct javascript to use?
I have tried to preview in a web browser. Doesn't work. I've tried publishing to Flash 8 and to Flash 7. It does not work for either. I went in and changed the script in the publish folder so that the javascript should work in Flash 8. Still did not work.
I tried the print slide widget on the screen. It works but I don't want them to have to choose a slide. I simply want them to be able to print the screen with the membership card.
I do not know javascript. Is there a source of simple javascript codes to use in Captivate?
Jennifer
Hi there
Perhaps a couple of things to try.
Thing 1 - Does it work if you ensure Flash 7 when you publish?
Thing 2 - If that fails, perhaps try adjusting the Flash Security Settings using the link below:
Cheers... Rick
Rick,
I changed the Flash security setting and it worked. Thanks for your help. I
am doing this as a volunteer project for the Junior Rangers for the
Chattahoochee National Park. It's to encourage children in 4th thru 6th
grade to come out to the park and learn about the natural resources
especially our most valued source, water. So, the Park and the Atlanta area
Junior Rangers all thank you for your help.
Jennifer
