I downloaded the free trial of Presenter today. I completed a presentation and clicked "Publish" and got the following error message:
"You will need to upgrade Adobe Flash Player before using this option."
I have gone to the Adobe site and installed the latest Flash Player, rebooted the computer and tried to publish it again, but I get the same error message.
The Presenter trial is Version 7 and I am running PowerPoint 2007 on Windows Vista.
What do I need to do to fix this? Thanks so much!
I am having the exact same issue. I'm frustrated at this point.
I am also getting this error (see error dialog above). I am running Adobe Presenter 6.2 and have Adobe Flash Player 10,0,22,87 installed. I have tried uninstalling the flash player and installing verion 9 with no success. I have tried uninstalling and reinstalling flash player 10 with no success. I have tried uninstalling Adobe Presenter and Flash player 10 and then reinstalling both with no success.
Please help Adobe!
Couple of issues come to mind...
First if you using 32bit or 64 bit Vista make sure you install the Flash Player as Administrator...
If your using 64bit Vista flash will only run in the 32bit version of Internet Explorer..
I solved the issue simply by running the Adobe Flash Player uninstaller, rebooting IE to clear all uninstalled Flash Player ActiveX control files and reinstall Flash Player 10. Issue solved on my end and it was once again a good day!
Hey keanna,
I already tried uninstalling the Flash player using the uninstaller from Adobe as you mentioned with no success. This did not solve the error for me. What do you mean when you say "rebooting IE to clear all uninstalled Flash Player ActiveX control files"??
Here is my OS and software specs:
Windows XP
PowerPoint 2007
Adobe Presenter 6.2
The error occurs when selecting publish from within PowerPoint - Presenter Add-in.
Hi Sage,
I know. I was having the same problem but with Presenter 7 and in Windows Vista. I also had to install IE 8 fresh before I re-installed the flash player 10. In other words, a fresh browser install and a fresh flash player install.
Ok, so I think I have an answer. I use Firefox as my default browser. Since PowerPoint is a Microsoft product, I decided to check and see if the Flash plugin was installed on Internet Explorer. I discovered that it was not, even after installing the stand alone Flash Player. Once I successfully installed the Flash Plugin for IE7 I solved my problem with Presenter and PowerPoint. Hope this helps someone else out there.
