I am trying to generate a project as WebHelp and after about 10 minutes of generating, the following error message appears: "Adobe RoboHelp 8 has encountered a problem and needs to close."
I am able to generate all other projects, just not this project.
This project is not on the network. It used to be on the network, but I moved it to my local directory awhile ago.
I tried restarting the computer. I tried generating from another computer and that did not work either.
I tried repairing the CPD through Microsoft Access. (I am not able to rename the CPD, because when I do that, almost all of my topics appear as broken links, so I use Microsoft Access to repair the CPD instead).
Is there anything else I can check or try?
Debbie
The CPD is created from RoboHelp's internal files so a repair will not necessarily fix the issue as Access will not know what to look for. A rebuild is what is needed and it should not result in the broken links you are seeing. However, that can happen and I have seen it. After repairing the links, I had no further problems. Try generating a CHM first as if that will create, it may make changes to the HHP that prevent the broken links. Also take a look in the HHP for any obvious path errors.
Do you have many folders in the project? If not, creating a new project should not be too painful as you can import all the topics in a folder in one hit.
Thanks. I didn't see anything in the .HHP.
However, I think I'm getting closer to finding the solution (at least I
think I've found the problem).
I have various conditional tags. One is called "uni2" and one is called
"Remove_in_uni2".
When I generate with "uni2" excluded and "Remove_in_uni2" included, the
WebHelp generates.
When I switch them ("Remove_in_uni2" excluded and "uni2" included), then I
get the error.
I tried removing the underscores - didn't work.
I tried renaming it to RemoveIn18 - didn't work.
Any suggestions, anyone?
Debbie
To: Debbie Sarig <debbie_sarig@magicsoftware.com>
Date: 06/18/2009 09:06 AM
Subject: Adobe RoboHelp 8 has encountered a problem and needs to close.
one hit.
See http://www.grainge.org for RoboHelp and Authoring tips
Try creating new layouts.
I tried creating new layouts. I was able, for instance, to create a CHM,
but then when I tried the WebHelp, it still didn't help.
I made a backup copy, removed the conditional tags, but I am still having
the problem.
Date: 06/18/2009 12:19 PM
Just out of interest did you create a completely new layout (good) or duplicate the existing one (bad)?
Read the RoboColum(n) for mutterings on RoboHelp, Technical Communication Suite and technical communication.
If I understand correctly, a new layout is a layout that I've never used
before.
I just tried and generate it as a Flash Help, which I've never done before.
I received the same error with this layout.
Date: 06/18/2009 07:04 PM
Read the http://notcolin.wordpress.com/ for mutterings on RoboHelp,
No. Right click in the Layout pod and select New Layout and create another webhelp layout. Do not create a duplicate as that will duplicate the problem, if it is in the layout.
This has solved my problem! Thank you so much.
I was not even aware of that option.
Kindest regards,
Debbie Sarig
Date: 06/18/2009 08:31 PM
This worked once and then I realized I had to switch some conditional tags
around and the problem started again.
Reading your posts submitted via email is a nightmare! Can you respond via the web to make it easier to read the thread?
Start by trying using build expressions with just one tag and then different combinations to try to track when it crashes.
I apologize for my unsightly emails. Hope this is better.
In the end, I deleted the .cpd and .xpj file. I opened the .hhp file through RoboHelp and the WebHelp generated properly.
Another issue that may have caused the problem was that the HTML Help Workshop was not working properly.
(When I just tried to click on the. hhp file, I received an error message about the HTML Help workshop and then it crashed. I reinstalled it before opening the .hhp file via RoboHelp.)
Thank you,
Debbie
No apology needed.
Deleting the CPD is a recognised fix for a number of problems but best not to delete the XPJ.
Glad to hear it is all fixed.
