How do you publish your table of contents with the TOC books automatically expanded when you publish?
I have a need to publish my table of contents with the books expanded by default. Is this possible? If it is, how do I do this and will I be able to collapse the folders once published as a preference?
See before & after images of what I am referencing for more details.
Hi there
I think the only way to do that is by generating a Section 508 enabled WebHelp output. As most folks are creating DHTML output, there simply isn't a way to make it happen.Especially if the output is a CHM.
Well, I'd be lying if I said there's just no way. One method would involve having a single Book in the TOC. Then configuring the TOC to auto-synchronize. Then configure a topic inside the book to be the default topic.
Cheers... Rick
