hi,
i'm publishing to Air from Flash CS4 Pro.
We created a certificate to embed which was publshing our Air files successfully a few weeks ago.
We have tried to publish the same files today for a client and Air produces the following error:
"There was an error connecting to the timestamp server. You may no have a connection to the network, or the server itself may have a problem."
We are connecting to the default timestamp server which i assume is:
https://timestamp.geotrust.com/tsa
but if navigated to this url directly i get a "404 missing" error
can anyone help with why?
is this server down or should we be using an alternative timestampe server - if so what and how do we go about this?
regards, and thankyou in advance,
Rich
It appears to be working now. (It isn't a web server, so navigating a browser to that URL doesn't do anything useful.) If you are still having trouble, you should look at your internet connection. I don't know of an alternative server, but you can turn off time-stamping (not recommended for a publically-distributed build) with the -tsa none option.
