I have managed to pull my data from the database and return it as XML. However, if the data is a single record, it will not populate the ArrayCollection variable.. it returns on the Object. (Which I'm sure most of you know.)
So what is the simplest way to display the record in a datagrid (or for that matter onto a form) if there is only that one record?
Seems it should not be too difficult. After all, it's only one record.
Total Likes
The ArrayCollection object will be populated only when you will have more then one object in your recordset. Now for displaying one record in data grid you first need to count the length of populated ArrayCollection object if it contain more then one record then simply say datagrid.dataprovider = ArrayCollection object and if the length of ArrayCollection is 0 or object in null then take your database reord in an object say myObj : Object = database record and then set datagrid.dataprovider = myObj
Hope this is clear to you.
Total Likes
Well, here's what I tried.. and it doesn't seem to be working.. it shows that "bratData" is "null"...
<mx:Script>
<![CDATA[
import mx.rpc.events.ResultEvent;
import mx.collections.ArrayCollection;
[Bindable]
public var bratData:Object;
public function resultHandler(event:ResultEvent):void {
bratData = event.result.brats.brat;
</mx:Script><mx:WebService id="srv" wsdl="http://blah.blah.com/mycfc/db_getBrat.cfc?wsdl" useProxy="false" showBusyCursor="true">
<mx:operation name="getaBrat" resultFormat="xml" result="resultHandler(event)">
<mx:request>
<contactID>
{12345}
</contactID>
</mx:request>
</mx:operation>
</mx:WebService><mx:DataGrid dataProvider="{bratData}" width="726" height="194" horizontalCenter="0" top="10">
<mx:columns>
<mx:DataGridColumn dataField="contactid" headerText="Contact ID" />
<mx:DataGridColumn dataField="firstname" headerText="First Name"/>
<mx:DataGridColumn dataField="lastname" headerText="Last Name"/>
</mx:columns>
</mx:DataGrid>
<mx:Button label="Get Data" click="srv.getaBrat()" x="25" y="212"/>
However, when I test the webservice using a standard call from a coldfusion page, I do get data in XML format.. here's what I get:
xml document | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
XmlComment | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
XmlRoot |
brats |
So my webservice IS returning an XML record.
Any suggestions?
Total Likes
Hi LeeMahn,
I have been looking for a solution to that for hours yesterday. And, then I came across this post:
http://polygeek.com/305_flex_what-happens-when-an-arraycollection-isnt-an-array#comment-30779
(see comment #3 there)
It did help me. Hope, you'll find that useful too There are a few typos in that code example, but I think it is easy to figure out how it works.
Total Likes
Thanks.. I'll look at that.
Take care...
Total Likes
Hey leemahn,
did u get any way to fix it?
if so plese do post the solution!
Bhavika
Total Likes
