1. Re: New version...old files????
Eddie Lotter Jun 25, 2009 6:07 AM (in response to Tom Mullica)Welcome to the forums.
No, you do not need to do anything special, however I would recommend that when you open a 2.0 project in CS3, save it to a new name. That way you will be able to open the original project in 2.0 if you ever need to.
You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
Cheers
Eddie -
2. Re: New version...old files????
Tom Mullica Jun 25, 2009 10:54 AM (in response to Eddie Lotter)Eddie...
THANKS very much for the advice. Would you suggest deleting 2.0
before installing CS3 or keeping them both until all is understood?
Is there much of a learning curve for CS3? I learned 2.0 with Adobe
Premier's classroom in a book so yesterday ordered classroom in a book
for CS3.
Thanks again for taking the time to write/help.
Tom
Sent from my IPhone (that's why it's so brief)
3. Re: New version...old files????
Eddie Lotter Jun 25, 2009 11:05 AM (in response to Tom Mullica)I would recommend keeping 2.0 around for a while, especially if you are in the middle of some projects. Complete them first and only start new projects in CS3.
There are some new features you are going to like in CS3. The tutorials I pointed you to will cover the changes, as will the Clasroom in a Book.
Otherwise CS3 works much the same as 2.0 did.
Cheers
Eddie -
4. Re: New version...old files????
Bill Hunt Jun 25, 2009 11:57 AM (in response to Eddie Lotter)Eddie has already covered this, but I wish to "second" his rec. for doing a Save_As with an incremented name, or similar. If not, and something happens, you will not be able ot go back.
Also, other than CS3 having Encore bundled with it and a bit more linking via DL, there will be little difference - oh, and HD support in CS3.
The only problem I've seen with versions co-existing was when one installed CS4 after CS3, and then they subsequently uninstalled CS3. This took some necessary CS4 files with it. Have not heard of any issues between PrPro 2.0 and CS3.
Good luck,
Hunt
5. Re: New version...old files????
Tom Mullica Jun 25, 2009 2:11 PM (in response to Eddie Lotter)Thanks a million, Eddie
Tom
6. Re: New version...old files????
Tom Mullica Jun 25, 2009 2:28 PM (in response to Bill Hunt)Thanks a million, Hunt
tom
