Can somebody help me to solve the below code issue - when user clicks on the "flash1.swf", I want to open in new window and play the media player?
Right now below code plays at same place....
<script language="JavaScript">
function Player(whichone,cnt)
var idisplay = document.getElementById(whichone);
if (idisplay.style.display == "none")
idisplay.style.display="block";
else
idisplay.style.display="none";
</script>
<a href="##" onclick="Player('Player1','temp1');" style="vertical-align:top;">flash1.swf</a>
<div id="player1" style="display:none">
<table>
<tr>
<td>
<OBJECT ID="temp1" WIDTH="255" HEIGHT="250" CLASSID="CLSID:6BF52A52-394A-11D3-B153-00C04F79FAA6"
VIEWASTEXT TYPE="application/x-mplayer2">
<PARAM NAME="URL" VALUE="flash1.swf">
<PARAM name="autostart" VALUE="false">
<PARAM name="ShowControls" VALUE="true">
<param name="ShowStatusBar" value="true">
<PARAM name="ShowDisplay" VALUE="false">
<EMBED TYPE="application/x-mplayer2" SRC="flash1.swf" NAME="MediaPlayer" WIDTH="192" HEIGHT="190" ShowControls="1" ShowStatusBar="1" ShowDisplay="0" autostart="0"> </EMBED>
</OBJECT>
</td>
</tr>
</table>
</div>
write a separate page, newpage.cfm that has the code to run the player.
call it like this
<a href="newpage.cfm" target = "_blank">text </a>
add url variables as required.
Please try this
<script language="javascript">
function viewPopUp(arg1,arg2)
myWindow=window.open('file2.cfm','file2','width=400,height=400')
</script>
<a href="##" onclick="viewPopUp('Player1','temp1')" style="vertical-align:top;">flash1.swf</a>
Hi there,
how about you use the new cfwindow tag? heres what you can do, ceate a cfwindow then pass on your javascript variable, and display the code in there. Now, note that cfwindow takes full html syntax. For example, an <html> tag down to end </html>. Ill how you an example:
<cfwindow name="example" title="here is my video" modal="yes" initshow="false">
<html>
<head>
<script>
</script>
<body>
</body>
</cfwindow>
and now initialize your content in the cfwindow, and make it dynamic with whatever you wanna display using javascript. Get creative
please let me know if that helped
Ali
