Okay, I'm having the same issue. Where is the disc tab to set the title remote? Sorry, my eyes are not finding it.
Also, I have one issue with a multi level menu. When the client is in the main menu, they click on a button and play the mpg, its fine. But if they decide to click the menu button on their remote, it takes them back to the main menu, allows them to press any button, but it stays on the menu and won't play any mpg. Do I change that in the authoring of the 'menu override'?
Thanks all for your help, Christine
CZorn wrote:Okay, I'm having the same issue. Where is the disc tab to set the title remote? Sorry, my eyes are not finding it.
Encore no longer has a Disc tab: it's now called the Build panel. But an easier way is to go to the Flowchart and select the Disc icon. Then look at the Properties panel.
Overrides have nothing to do with this. Overrides replace the end action of the targeted object.
The menu button on a DVD player toggles between a playing timeline and a menu. It cannot be used to go from one menu to another.
DVDs have a title or top menu, which will take the user to the menu specified for title remote. Timelines have a menu property, which takes you to the menu specified for the timeline (menu remote). The two should not be confused.
In response to 16:9 4:3 -
I had that issue a while back. Can't remember if I went into preferences and changed the preview or you could try right clicking on the m2v and interprete to the size you want. If this doesn't work, you may have to go back to your encoding and make sure the settings didn't mess up. Once you select a setting and then customize it, check your settings one more time. Not an expert, but hope it helps. Christine
I had the same issue (couldn't figure out how to set "Title Remote" with Encore CS3 and CS4 but worse still, I COULDN'T set it to what I wanted, I could only set it to STOP, not the beginning of my openning movie (I'm just making a simple movie, no first play besides the one and only movie). It wouldn't allow me to choose what I wanted by browsing with the little fly out menu right hand arrow to the right.
THEN I stumbled onto this idea, I used the little icon (can't remember it's name, "pick" something or other, the icon you can drag from to set it's source, it's the little icon that looks like a whirl to the left of "Title Button" on the Disk Properties panel) and just dragged it to the timeline that I wanted to be the title remote and viola! it works!
Dave
Dave,
That little icon is the "Pickwhip."
Glad you got it working,
Hunt
Hi there:
Long ago solved and off to the happy client. Thanks for the update though.
Christine Zorn
PAN Video Services Inc.
Guelph, Ontario
office 519 836-8822
cell 519 823-6130
www.panvideo.com
Winning Solutions Since 1989
Being happy doesn't mean everything is perfect,
it just means you've decided to see beyond the imperfections.
Even when I turn Title Remote off in Permitted Operations, it still comes up as a problem on the Build Check in Encore CS4.
And even if I turn Title Remote off in the Build Check, I still get the error/ignore popup when I go to make the DVD.
This is for DVD that need to just start playing the timeline when inserted to play (no menus or or anything).
It is kind of disconcerting...
You can still have an AutoPlay DVD-Video with the Title Remote set. That is to tell the player what to do, should the user hit Title on the remote.
That message is just informative and is not an error, per se. It will pop-up twice, once on Check Project and also when one goes to Build DVD.
Good luck,
Hunt
