Hi, I'm trying to import a number of PDF files that I'll then link to within my help file. I keep getting an error that Robohelp is unable to import them due to the file being an "unsupported file type, or the file is corrupted." I don't see how they can be corrupt when I created them just minutes before and they open fine. Any help would be appreciated! Thanks in advance.
Jeff
Hi Jeff
Okay, now we are cooking!
What you need to do now is to add these PDFs to your list of Baggage files.
From the RoboHelp HTML Project pod, you should see a Baggage files pseudo folder if you are in Classic view. If you are in the new Global view you won't see it.
If you see the Baggage Files pseudo folder, right-click it. If you don't see the Baggage Files pseudo folder, right-click the Project Files pseudo folder.
Click New > Baggage File.
This should present a dialog allowing you to choose th
...Copy link to clipboard
Hi there
We need to clarify exactly what you are attempting to do.
And how exactly are you attempting to "import" the PDF(s)?
Cheers... Rick
Helpful and Handy Links |
What version of RoboHelp and what was used to create the PDFs?
Ok, let's see...
I'm using Robohelp 8. What I did was, exported my help file to multiple word documents where I reformatted them. I then right clicked on the saved word document and selected "convert to PDF". What I'd like to do is, import these back into my Robohelp project so I can add links in my help file where users can download and print if they wish.
Jeff
Hi Jeff
This should present a dialog allowing you to choose the document(s). (you may add more than one at a time)
After you get them added as Baggage, you are able to link to them.
Cheers... Rick
Thanks for the tips guys. Rick, I'll give this a try now.
Just tried it and worked perfectly
Jeff
