I'm a newbie to this. I have Acrobat 9 Pro. I have designed a file in Livecycle with dropdown list and the usual data fields. The client would like the entire form sent back as a PDF. So my submit button is configured accordingly.
However when doing a test and receiving the returned file on another machine with Reader 9, I find that I am able to change the data.
Is there a step I am missing out in form creation?
Many thanks
Total Likes
What do you mean by change data? If they can modify fields on received PDF form, you had to set all fields as read only, this will prevent form from future modyfying.
BR,
Paul Butenko
Total Likes
Scenario is this : respondant gets form in email - fills in data and submits by email to form receiver. The form is returned as a pdf. For some reason the data is not locked. The form field data can be changed although form collector only has Acro reader 9.
The request by client is to receive the complete pdf with data and not just xml data. Tried the read value but this then prevents data from being entered into the form by respondant.
Total Likes
On preSubmit event of fileds which should be locked you can put this script:
this.access = "radOnly";
It will make your fields locked from changes.
BR,
Paul Butenko
Total Likes
This sounds lgood but at the risk of being a pain and an idiot, where do I find this? I looked under help file and they do mention this cmd but nowhere do they say where. Is it somewhere in each form field or with the submit button?
Total Likes
It is on each field.
Total Likes
Paul can I prevail on your patience a bit longer. This is uncharted waters for me. When I select the presubmit event the display is this
form1.#subform[3].Ops::preSubmit:form - (FormCalc, client)
where and how do I insert the
many thanks Alex
Total Likes
You have chose FormCalc as script language, but scrip written in Javascrip. You can change script to FormCalc style - $.access="readOnly", or change it ot Javascript:
BR
Total Likes
