5 Replies Latest reply on Jun 29, 2009 8:29 PM by rajdudi
    Remove Instance from a Form at run time
    rajdudi
      I want to remove the rows of a table in a form at runtime.
      I have created the table by customising a button and writting javascript.
      now i want to delete some rows of the table by another button,.
      For example i added 4 rows in above form and i want to delete 2 rows (1st and 3rd)
      when i click remove button it will delete only 1st row.
      the java script of remove button is like this:
      for(i=xfa.form.plan.planDocument.plan1.task.instanceManager.max;i>=1;i--)
      if(i>xfa.form.plan.planDocument.plan1.task.instanceManager.min)
      if(plan.planDocument.Header.plan1.task.Table5.Row1.rowdelete.rawValue==1)
      xfa.form.plan.planDocument.Header.plan1.task.instanceManager.removeInstance(0);
      This deletes only the first row that is selected
      How can i do this.
      The instanceManager.removeinstance() method delete only the first row of the all selected rows..
        • 1. Re: Remove Instance from a Form at run time
          rajdudi Level 1
          Replyyyyyyyyyyyyyy?????/
          • 2. Re: Remove Instance from a Form at run time
            madhu_livecycle
            Hi rajdudi,
            replace ur line
            with
            xfa.resolveNode("form.plan.planDocument.Header.plan1.taskTable5.Row1.instanceManager.remov eInstance("
            +i+")"); have a try.
            by passing i to removeInstance, it knows the index of the row to delete
            Madhu.
            • 3. Re: Remove Instance from a Form at run time
              rajdudi Level 1
              Hi Madhu,
              Thanks for the reply.
              But the changes you advised me to make in the script are not working to give the required result.
              xfa.resolveNode("form.plan.planDocument.Header.plan1.taskTable5.Row1.instanceMan ager.removeInstance("
              +i+")");
              In this script the if statement always checks the first row of the table and then Removeinstance removes the ith row of the table irrespective of the status of Delete check of that row.Whethre it was checked or not.
              For example 1st row is checked and i=2 then if then this script will remove the 2nd row.
              I want the script deletes all the checked rows only
              • 4. Re: Remove Instance from a Form at run time
                madhu_livecycle Level 1
                Hi rajdudi,
                please find the attached sample form.
                i have written a script for Delete button in click event which calls a function
                removenull.removecheckedrows()
                code in click event of button
                var
                tlength = xfa.resolveNodes("body.Table1.Row1[*]").length;
                for
                ( var j=1; j<tlength; j++)
                if(!removenull.removecheckedrows())
                break;
                else
                continue;
                and written a function
                // Function to remove the Checked rows from Table1
                function
                removecheckedrows()
                var tlength =
                for ( var i=0; i<tlength; i++
                if(xfa.resolveNode("body.Table1.Row1["+i+"].CheckBox1").rawValue ==
                1 )
                body.Table1.Row1.instanceManager.removeInstance(i);
                return true
                // end function
                which will remove the selected rows.
                try to implement this in your form
                if u r unable to download attached form give ur mailid i will forward the same.
                Madhu.
                • 5. Re: Remove Instance from a Form at run time
                  rajdudi Level 1
                  Hi Madhu,
                  I am not able to download the attachment in your reply.
                  Please send me that from at rajdudi@gmail.com
                  Raj Dudi
                  9764006704 | Pune
